2004 Saturn L300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26466
Printed Date: April 01, 2026 at 4:17 PM
Topic: 2004 Saturn L300
Posted By: Falcon 1
Subject: 2004 Saturn L300
Date Posted: February 14, 2004 at 2:14 PM
Hey I am working on a Saturn L300 sedan I need info on how to wire door locks on this vehicle. When I check lock and unlock wires they have neg 12volt at rest and then goto aprox pos .6 volt when pressed. The same goes with the trunk release.
------------- Do it right the first time, only a doctor can bury his mistakes.
Posted By: kgerry
Date Posted: February 14, 2004 at 2:17 PM
lock and unlock should be positive in the low part of the drivers kick
Posted By: Falcon 1
Date Posted: February 14, 2004 at 2:27 PM
The wiring info I have says to wire them at the BCM behind glove box.
Posted By: kgerry
Date Posted: February 14, 2004 at 2:30 PM
WM shows them as positive in the lower loom in the DKP
Posted By: Falcon 1
Date Posted: February 14, 2004 at 2:36 PM
Ok I will check the DKP. I am installing a Pro-start system in the saturn it has an external trigger wire to remote start is it possible to wire the panic button from the original remote and then I would not have to wire door locks or trunk and the customer can use the factory remote for everything. Just a thought.
Posted By: kgerry
Date Posted: February 14, 2004 at 2:40 PM
keep in mind range with the OEM fob is like 75 feet... kinda sucks for remote start purposes
Posted By: Falcon 1
Date Posted: February 14, 2004 at 2:43 PM
Yes that would suck I will still try the DKP thanks for the help.
