2003 chev full-size diesel remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26571
Printed Date: April 01, 2026 at 6:52 AM
Topic: 2003 chev full-size diesel remote start
Posted By: plywood
Subject: 2003 chev full-size diesel remote start
Date Posted: February 16, 2004 at 10:25 AM
I tried to install a DEI remote start on this vechile it, but it starts and then dies right away.  I got my wiring diagram from DEI.  The Passlock II bypass seems it be working fine, the Anti-theft light doesn't come on at the wrond times.  I did not use the data-bus mod. because I'm using the lock motor as a positive pluse to active the unit.  Also there was a keysense wire listed as lt. green, I found two lt. green wires, but I could not tell which one was the proper wire.  Could that wire not being hooked up cause it to die right away?  I've heard that there maybe be a third ignition wire that needs power??  Any help would be great! Thanks.
Matt
Always remember to test wires with a Digital Multimeter!
Posted By: Velocity Motors
Date Posted: February 16, 2004 at 10:41 AM
Hey Matt, where did you end up getting the tach and wait to start wire from ? Also, what bypass module did you use for the truck ?
Posted By: draasch
Date Posted: February 16, 2004 at 10:44 AM
see if this info helps
Ignition #1:
   Pink
Ignition Switch Harness
Ignition #2:
   White
Ignition #3:
   Used for Bypass
Accessory:
   Orange
Ignition Switch Harness (Hot in run only)
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: draasch
Date Posted: February 16, 2004 at 10:45 AM
sorry posted too fast..
put a key in the ign. and see if everything work fine. if so start with the bypass unit...
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: plywood
Date Posted: February 16, 2004 at 11:52 AM
I got the tach and wait to start wires  from another installer that I know in town here.  I'm using a DEI 555L for the passlock II.  I put the key and tried it in run position and it still died right away.  If I just turn it really quick while the unit is cranking it will run, and stay running even if I take the key out.  Also the DEI unit dianogic is telling me it is shuting down from "low or no RPM".  Even though, when I programed the tack it took right away.
Matt
Matt
Posted By: plywood
Date Posted: February 16, 2004 at 11:53 AM
Those are the Ignition wire that I used.
Matt
Posted By: plywood
Date Posted: February 16, 2004 at 11:59 AM
sorry about all the posts, I keep noticing more things.
David you posted:
Accessory:
   Orange
The heavier gauge orange wire that I used, for Accessory, was hot in the run and with the key turned backwards. (I'm pretty sure that is what it tested, but it is not here right now)  Do you think there is a good possiblity that there maybe another orange wire that I should have used instead?
Matt
Date Posted: February 16, 2004 at 12:48 PM
It's your Passlock bypass that's not working properly then from what you described in your response. Double check all your conections and post what wires you used for the Passlock bypass.
Posted By: plywood
Date Posted: February 16, 2004 at 1:01 PM
I think that it is working right, becuase the anti-theft light only seems to come on at the propper time.
I used the ORANGE / balck wire as the passlock ground reference.  When I was finding the yeallow wire, there was two of them, so I cut the one that I thought it was with the key on.  As soon as I did that, the Anti-theft light came on, I used that yellow wire.
Matt
Posted By: kgerry
Date Posted: February 16, 2004 at 1:09 PM
you may need to use the 456G module cause if i remember correctly there is also an ignition kill as part of the OEM security..it shuts down the ignition circuit...i've used 555L and 456G on these and never had any problems at all
