2003 Ford Taurus, Horn and Door trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26574
Printed Date: April 01, 2026 at 7:21 AM
Topic: 2003 Ford Taurus, Horn and Door trigger
Posted By: don88
Subject: 2003 Ford Taurus, Horn and Door trigger
Date Posted: February 16, 2004 at 11:46 AM
I installed a keyless entry system this weekend. Every thing is working. However, I was not able to locate the Horn, and door triger input wires. Can you give me specific help on location and wire color.
Posted By: draasch
Date Posted: February 16, 2004 at 1:36 PM
Make:   Ford
Model: Taurus
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 502
Alarm
Constant 12 volts LT.GREEN/ VIOLET IGNITION SWITCH HARNESS
Ignition 12 volts RED / LT.GREEN IGNITION SWITCH HARNESS
Starter RED / LT.BLUE IGNITION SWITCH HARNESS
Dome Light YELLOW (-) AT INTERIOR LIGHT
Trunk Pin Switch WHITE/ YELLOW (-) AT MODULE TO LEFT OF STEERING COLUMN
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW DRIVERS KICK PANEL #201
Power Unlock PINK/GREEN DRIVERS KICK PANEL
#201 See Negative Pulse Door Lock Diagram
OEM Horn D BLUE (-) STEERING COLUMN HARNESS
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: NowYaKnow
Date Posted: February 16, 2004 at 6:26 PM
Horn is d. blue (-) @ a small connector to the right of the steering column. Door trigger is BLACK/ blue (+) in the drivers kick panel running along the door sill and covers all doors. Good luck,
Mike
Posted By: JWorm
Date Posted: February 16, 2004 at 10:07 PM
Ford puts their horn trigger in the same plug as the airbag wires.
Posted By: don88
Date Posted: February 17, 2004 at 5:06 PM
Thanks for you specific instructions. I will try them this weekend. What should I consider before disconnecting the air bag wires?
Date Posted: February 17, 2004 at 5:59 PM
"What should I consider before disconnecting the air bag wires?"
There is no reason to disconnect the air bag wires..I would definately recommend NOT disconnecting the clockspring harness..Put your meter to read DC volts and test the thin dark blue wire in the small connector to the right of the steering column. If there is no dark blue look for a yellow/blue. It should sit at ~ 12 volts or so and voltage goes away when you push the horn. Good luck,
Mike
