URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26743
Printed Date: March 17, 2026 at 4:26 AM
Topic: Neons/LED connected to alarm
Posted By: papacubanlover
Subject: Neons/LED connected to alarm
Date Posted: February 18, 2004 at 6:11 PM
------------- live each day expecting to die
Replies: Posted By: Teamrf
Date Posted: February 18, 2004 at 9:28 PM
You may want to check the amperage draw on those lights before you do this. It may kill your battery if it draws too much current. But I would think you just tap the 12volt wire into your LED wire/
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: draasch
Date Posted: February 18, 2004 at 9:45 PM
most led are low voltage. 1-2 volts you may be asking for trouble for try to hook them up to your LED.
------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: wblakes
Date Posted: February 18, 2004 at 10:12 PM
i would tap the neons into the parking lights for they flash when you arm and disarm. also put a switch between the neon and parking lights so you have the ability to turn them off when not needed.
Date Posted: February 18, 2004 at 11:10 PM
draasch wrote: most led are low voltage. 1-2 volts you may be asking for trouble for try to hook them up to your LED.
Thanks for info is their an alternative in connecting to LED or can I use a realy of some sort to eliminate troubl;e with low voltage?
Date Posted: February 18, 2004 at 11:14 PM
As Wblakes wrote "tap it into the parking light" I am actually wanting to have it so the undercar lights are on with the alarm not just the status indicator. This might be to much of a draw for the neons but I wouldn't think the LED's if so worse case maybe to the washer nozzles or something simple like that
Thanks for the responses
Posted By: clearman
Date Posted: February 19, 2004 at 9:04 AM
Let the led output of the alarm activate the coil of a relay, don't let it run directly to any of these lights, it will burn up your output. With a relay, you can have anything you want to flash with the led, as long as it doesn't pull so much power that it drains your battery.
Posted By: xetmes
Date Posted: February 19, 2004 at 9:48 AM
i would run the led to a transistor then to a relay.. but it would kill the battery if left on for any good amount of time...
