Difference between 790xv & 791XV?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26761
Printed Date: April 29, 2026 at 12:14 PM
Topic: Difference between 790xv & 791XV?
Posted By: max7687
Subject: Difference between 790xv & 791XV?
Date Posted: February 18, 2004 at 9:25 PM
Was wondering what's the difference between the Viper 790XV and 791XV? I currently have a Hornet 553T and thinking about upgrading to the two way transmitter and was wondering what's the difference between the two models stated earlier? Thanks!
Posted By: wblakes
Date Posted: February 18, 2004 at 10:06 PM
the two are very similiar, one is a 2002 model and the other is a 2003 model. the 791 has many improvements over the 790. a lot of people are complaining that the 790 has many bugs; which are fixed in the 791. i don't know about the others, but i like the silver remote on the 790. the blue remote on the 791 looks too much like a toy for me. i would go with the 791 because it's better and not because of the remote.
Posted By: kgerry
Date Posted: February 19, 2004 at 9:17 AM
go with the 791 it uses the new micro relay satelite and like wblakes said some of the little bugs in the 790 were cured in the 791, also 791 has some new features the 790 doesnt. I kinda like the new remotes, they look a little smoother, i found the old remote too square and chunky
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: bd3521
Date Posted: February 19, 2004 at 6:23 PM
what is the "micro relay satellite"?
thanks
Posted By: kgerry
Date Posted: February 20, 2004 at 9:02 AM
the bank with all the relays-crank, ign, etc is about half the size on the 791 and it's self contained as opposed to the old style relay satellite that was a bugger to bury under the dash, especially once you added an extra relay for anti-grind.... go with the new model
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: rudbwoy69camaro
Date Posted: February 20, 2004 at 9:07 AM
Newer IS better.
Posted By: daniel2002p
Date Posted: February 20, 2004 at 9:33 AM
the 790 occasionally would go out, that has been fixed with the 791
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: Teamrf
Date Posted: February 20, 2004 at 7:57 PM
And it has a rear defroster.......with a pretty blue remote control.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
