Wiring Help 3rd ignition and IPPME bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26832
Printed Date: March 21, 2026 at 10:44 AM
Topic: Wiring Help 3rd ignition and IPPME bypass
Posted By: bt3668
Subject: Wiring Help 3rd ignition and IPPME bypass
Date Posted: February 20, 2004 at 11:16 AM
I am trying to install my autostart rs-850 system. I am confused on how to connect up the 3rd ignition wire. I have a 97 pontiac grand am. I have an IPPME bypass installed in the car from the system I am removing and replacing with the autostart. There is a brown wire from the IPPME that says to connect to (-) OUT WHEN RUNNING FROM CAR STARTER". there is a wire on the starter that says grounded out when armed and one that says grounded output when disarmed. Do I connect it to one of these wires? The other question I have is about the brown 3 ignition wire. The tech support I have been speakiing with says I need to use a relay to get it to work. I have a system installed now which i didn't install a relay. I am very confused now on what conections should be made for the main ignition connections. I included their reply below. Can anybody help clarify what exactly I need to do to finish this up. THANKS!!!
. I am a little confused on
> connecting the ignition 3 wire and what wire I should connect to
> my GM Bypass IPPME module. There is a brown wire coming from the
> bypass that needs to be connected to the autostart system. It is
> labeled as "(-) OUT WHEN RUNNING FROM CAR STARTER" . Can you
> explain the igniton 3rd wire? is this the brown wire at the
> ignition? the remote start i bought has a seperate relay and wire
> harness with it. Do I need to use it for this? If so can you tell
> me which wire are connected to which? I am also not clear on what
> you mean by light is + so connect to sw or go to the outside by
> parking light? Can you clarify this for me? I assume that all my
> other connections on my spreadsheet are correct? I currently have
> a remote start system in the car I am taking out to replace it
> with this one. It is the prostart 3300. I installed this one last
> year.
> goautosound@optonline.net wrote:hi
> your car has ignition 3 so you need to add a relay to make this work
> use second ignition out to trigger third relay
> and light is + so connect this by removing your sw or go to
> outside by parking light
> and if you are not doing window roll up
> you do not need to connect window sws
Posted By: bmf1000d
Date Posted: February 20, 2004 at 12:43 PM
Ok for starters you dont have a 3rd ignition on the grand am so no need to hook that up i only show 2 ign wires
Ignition  #1:
PINK
IGNITION SWITCH HARNESS
Ignition #2:
WHITE
Ignition  #3:
N/A
the other wire you should hook up is a ground when running if for bypass mod that you have i dont have the color code for an autostart.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Posted By: bt3668
Date Posted: February 20, 2004 at 12:54 PM
According to the wiring diagram i pulled from 12 volt there is a brown ignition 3 wire. Is this incorrect?
Posted By: bmf1000d
Date Posted: February 20, 2004 at 12:58 PM
thats the first time i have every seen a 3rd Ign on there....i have always just hook up the pink and white and it has worked for me
"Big" Mike
Double Take
Fremont, Ne
Posted By: kgerry
Date Posted: February 20, 2004 at 1:17 PM
the brown is an accessory wire and isnt needed for RS
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
