Door Locks Frontier 02
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26887
Printed Date: March 20, 2026 at 3:53 AM
Topic: Door Locks Frontier 02
Posted By: ull3030
Subject: Door Locks Frontier 02
Date Posted: February 21, 2004 at 8:44 AM
I installed a larger pair of sprakers in the rear doors of my 02 Frontier crew cab, and I drilled through the wiring harness in the door.  Now my power locks are not working.  I removed the screw and taped the skinned wire.  I can hear the control box under the dash ckicking when I press the lock switch.  I cannot think of anything else to check.  Is it possible that all the actuators are now damaged?  Or possible the keyless entry system.
Thanks for any help
Posted By: ull3030
Date Posted: February 23, 2004 at 6:12 PM
I repaired the problem, I had a ground trace burnt on the board.
Thanks for any help
