Alarm system identification
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26902
Printed Date: March 19, 2026 at 4:27 PM
Topic: Alarm system identification
Posted By: davanhorn
Subject: Alarm system identification
Date Posted: February 21, 2004 at 1:12 PM
Hello all. I just purchased a used Nissan Pulsar and unbeknownst to me at the time, the car has an alarm system. For one reason or another the alarm had been disabled. I reconnected the system, located a valet button and after feeling my way through it some have determined that the system is in perfect working condition. I am interested in purchasing a remote control for it but can't as I'm having trouble identifying the exact model #, and without that info cannot proceed with my purchase. I've contacted several alarm system/remote control retailers and they have told me that they can't help me unless I can supply them with these details. Any ideas???
Here's some of the physical characteristics of the brain.
The case is embossed with the word MICRO on the front.
There are two stickers on the back which are quite faded and thus can't read all the info on them but here's what I've been able to read.
One sticker has two sets of numbers of which one appears to be "1234567890" and underneath them is "0001110011" and underneath that is "CAT"
The other sticker has this "VER:2.1"
On the back of case are the connections and DIP switch settings of which are as follows.
RED / BLACK (+) LED OUTPUT
YELLOW (+) INGNITION SWITCHED
ORANGE (-) STARTER KILL OUTPUT
VIOLET (+) POSITIVE DOOR TRIGGER
VIOLET/WHITE (-) SENSOR TRIGGER INPUT
GREN (-) DOOR TRIGGER INPUT
GRAY (-) SECOND CHANNEL OUTPUT
BLUE (-) VALET SWITCH INPUT
bROWN (+) SIREN OUTPUT 3A MAX
RED (+) 12 VLT CONSTANT POWER INPUT
WHITE (+) LIGHT FLASH OUTPUT
BLUE/WHITE (-) UNLOCK OUTPUT
GREEN / WHITE (-) LOCK OUTPUT
SWITCH SETTINGS
1 ON-30 SECONDS LIGHT
2 ON-5 SECONDS DOOR LOCK
3 ON-5 SECONDS DOOR UNLOCK
4 0FF-SIREN FLASHING
5 ON-DOOR WILL LOCK IN PASSIVE
6 OFF-SIREN CHIRP OFF
7 ON-ACTIVE ONLY
8 OFF-ARMING AT 64 SECONDS
9 LOOP-CUT FOR CURRENT SENSING
Any help would be appreciated.
Posted By: kgerry
Date Posted: February 21, 2004 at 1:25 PM
have you done a search under Micro alarms, i'm sure you'll find what you're looking for.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: February 23, 2004 at 4:12 PM
Thanks for responding kjerry. Yes, I have done an exhausting search under Micro alarms and in doing so have found and visited Micro's website, downloaded most if not all of their literature, and even sent them an email requesting assistance. To my knowledge they've never responded, and upon viewing the literature and comparing it to the unit have determined that none of applies. I obtained an unused remote control from a friend and modified the circuit traces to match the trace configuration on the brain's mother board and this didn't work. I have spent alot of time scanning the net for clues, ideas, etc. and still have been unable to solve this one.
Posted By: videoviking
Date Posted: February 23, 2004 at 6:39 PM
try remotesunlimited.com  they know just about every alarm out there, and hey, guess what they sell?  remotes!
Chuck Johnston
Posted By: jrilla
Date Posted: February 23, 2004 at 8:02 PM
You can buy a brand new basic alarm system for about the same price you would pay for a replacement transmitter anyway.
Also, since you alsready have one installed putting in a new one will be easy.
J Rilla
Owner/Installer
