commando combo unit?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26924
Printed Date: March 19, 2026 at 6:33 AM
Topic: commando combo unit?
Posted By: prdjr165
Subject: commando combo unit?
Date Posted: February 21, 2004 at 7:28 PM
I installed a Commando fm870 combo unit and the remote start part won't work,The alarm and door locks work fine.The van won't even crank when i use the remote or when I ground the WHITE/ blue remote start test wire.I checked the brake wire and the hood pin wires and they are not the problem,I think it might be a bad brain.
Posted By: Velocity Motors
Date Posted: February 21, 2004 at 7:49 PM
Need more information. Vehicle make, year and model.
------------- Jeff
Posted By: prdjr165
Date Posted: February 21, 2004 at 9:41 PM
It's a 2000 dodge ram van.
Posted By: brianh
Date Posted: February 21, 2004 at 10:22 PM
You must Program the unit for the Remote start feature. You must chose either voltage checking,tach checking or voltage mode. Try this and it should work fine.
------------- Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Posted By: prdjr165
Date Posted: February 22, 2004 at 1:12 PM
I will try that,but shouldn't have started when I grounded the remote start test wire?
Date Posted: February 22, 2004 at 9:32 PM
What did you use for the starter wire on the van ??
------------- Jeff
Posted By: moby0906
Date Posted: February 25, 2004 at 10:36 AM
I am no expert but I put a commando 560 on my truck and you had to do the tach,voltage,etc check before it would let you attempt the remote start. it worth checking out before you tear back into the brain. let us know what you come up with moby
Posted By: prdjr165
Date Posted: February 25, 2004 at 6:16 PM
Yes,You guys are right!I had to program it before it would remote start,Thanks for the help!!!
