2002 Dodge Durango Unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27033
Printed Date: March 17, 2026 at 7:57 AM
Topic: 2002 Dodge Durango Unlock
Posted By: chronisj
Subject: 2002 Dodge Durango Unlock
Date Posted: February 23, 2004 at 10:41 AM
I saw in this thread: https://www.the12volt.com/installbay/forum_posts.asp?tid=6259&KW=durango+locks
that it is a one wire system now as apposed to the 3 wire system that was on the 1998 dodge durango. However in realy diagrams in the basics section it shows a one wire dodge caravan with a 246 ohm and a 1562 ohm resistor on it. Is the caravan different from the durango? Should I use a 649 or a 246?
Posted By: djfearny2
Date Posted: February 23, 2004 at 10:46 AM
it is a white green wire found at the ctm located in drivers kick pannel.
the resistance is 820 ohm for lock and 330 for unlock must use relays to isolate
Jon
Installer/Help Technician
---coral springs florida---
Posted By: chronisj
Date Posted: February 23, 2004 at 10:53 AM
did you read the thread at <a href=https://www.the12volt.com/installbay/forum_posts.asp?tid=6259&KW=durango+locks>here</a>?
he says 647 to lock, 1562 to unlock... I have 3 different answers, now... do you have a durango?
Posted By: chronisj
