Remote starter CT-3300 Accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27207
Printed Date: April 03, 2026 at 3:54 PM
Topic: Remote starter CT-3300 Accord
Posted By: mitch_w
Subject: Remote starter CT-3300 Accord
Date Posted: February 25, 2004 at 10:55 AM
I have installed a CT-3300 in my 2000 Accord LX -- partial success.  The unit will CRANK, but will not run unless the key is IN the ignition and turned to the first on position (blower off, radio on).  I have connected it according to the instructions, into the ignition harness wires.
Is there an extra security feature in the ignition key switch that's causing the problem?
The door lock/unlock with remote works OK.
Any suggestions?
mitch_w
Posted By: draasch
Date Posted: February 25, 2004 at 11:00 AM
did u use a bypass??? DB-PKH2 or a PASS4
Make:   Honda
Model: Accord
Year:    1999-2002
This Database Was Last Updated On:    6/9/2003
Index #: 1336
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH AHRNESS *
Dome Light BLACK/ WHITE (-) 4 PIN CONN. IN PASSENGER FUSE BLOCK
Trunk Pin Switch ORANGE (-) 18 PIN CONN. IN DRIVER KICK PANEL
Parking Lamp RED / BLACK (+) GREEN 20 PIN CONN. DRIVER FUSE BLOCK
Power Lock BLACK/ WHITE 2 PIN GRAY CONNECTOR IN #201
Power Unlock GREEN/ RED DRIVER KICK PANEL (LX MODEL) **
* Installing A Starter Kill Relay At The Ignition Switch Harness Before The Starter Wire Enters The Driver Side Fuse Block May Cause A "Check Engine" Light To Come On. Starter Wire Should Be Accessed After Fuse Block. **EX Model Access Door Locks At Passengers Side Multiplex 20 Pin GREEN Con Unlock BLU/ORN (-) Pin 4 Lock BLACK/ ORANGE(-)Pin 16.Behind Lower Cover. #201 - See Negative Pulse Door Lock Diagram.
Remote Start
Tach Signal BLUE WHT 2 PIN TEST CONN-PASS REAR ENGINE*
Ignition #2 YELLOW IGNITION SWITCH HARNESS #239
Ignition #3 N/A
Accessory WHITE/ BLACK IGNITION SWITCH HARNESS
Neutral Safety BLUE/WHITE (-) GREEN 20 PIN CONN DRIVER FUSE BLOCK
Brake Light WHITE/ BLACK (+) SWITCH ABOVE BRAKE PEDAL
Reverse Light GREEN/ BLACK (+) GREEN 10 PIN CONN DRIVER FUSE BLOCK
Rear Window Defrost BROWN / YELLOW (-) REAR DEFOGGER SWITCH
#239- See Immobilizer Bypass Diagram. * 4 Cylinder Models- 6 Cylinder Models Connector Is On Driver Rear Of Engine
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: mitch_w
Date Posted: February 25, 2004 at 11:04 AM
I did not install a "bypass".   Installed only what came with the basic kit.  What's a bypass for?
mitch_w
Posted By: davedyer79
Date Posted: February 25, 2004 at 11:20 AM
Did you install an immobolizer for the factory anti theft system.  That is why it is starting with the key in the ignition.  You can go to a car audio shop and purchase a bypass (like crimestopper), or you can do it the old fashion way and use one of the factory keys and wrap 30 guage wire around the plastic part of the key and the other end around the black plastic ring of the key cylinder.  The key side of the wire goes to pin 30 of a SPDT relay, the ignition side of the 30 guage wire goes to 87, +12V to pin 85, and ground when running, or ground when remote start to pin 86.  This tricks your immobilizer system, thinking a key is in the ignition when remote starting.  Secure the wire to the key and the ingnition ring very tightly with black tape.  You may have to adjust the wire numerous times on the ring and the key.
Check you connections on the primary ignition wires.  I show:
constant 12V      White
Ignition 12V        BLACK / YELLOW
Ignition 2             Yellow
Accessory           WHITE/ black
Starter                 BLACK/ white
BE SURE TO grab the starter wire that comes out of the fuse box.  There will be a relay in the fuse/relay box that will "click" when you start the car.  Put your finger on it to find it.  Pull the relay out, find the BLACK/ white wire coming out of the box, and test to see if throwing 12V when starting (the car will not start).  If not throwing, connect here.  If you connect the start wire at the ignition harness, it will activate the "check engine" light.
davedyer79
Posted By: kgerry
Date Posted: February 25, 2004 at 11:26 AM
there is a chip in the head of the key that allows the vehicle to be started, you have to replicate that code or the car wont start, just go to a local install shop and ask for the proper transponder bypass for that model of vehicle and off you go....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: mitch_w
Date Posted: February 25, 2004 at 12:00 PM
Thanks, guys, for the info.
A local car audio place will sell me the PKH2 (Honda) bypass for about $42 CA  [ $30 US ].
mitch_w
Posted By: draasch
Date Posted: February 25, 2004 at 12:17 PM
good luck
Good Luck
David
Ace Security
813-376-9778
Tampa
