Tach wire or voltage wire ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27280
Printed Date: April 02, 2026 at 6:02 AM
Topic: Tach wire or voltage wire ?
Posted By: daba58
Subject: Tach wire or voltage wire ?
Date Posted: February 26, 2004 at 11:21 AM
 What's the best place for you RS to hook up to on a 2002 GMC Serria. The alarm is a autopage 850lcd. Having problems tracking down the tach wire.
Posted By: tjdurham
Date Posted: February 26, 2004 at 12:21 PM
go to any coil pack under hood and there are 4 wires 3 of them are the same on all of the packs the odd color is your tach use any of themand youll be ok
tj
Posted By: daba58
Date Posted: February 26, 2004 at 12:42 PM
Well I found a tach wire and it's ok but not the truck turns over and dies. I have a DEI 555L and it's wired up right I think. Anything on my autopage alarm that would cause it not to fully crank over??????
chris
Posted By: draasch
Date Posted: February 26, 2004 at 12:55 PM
put a key in the ign. and try to start it again....if it stays running, then you dont have the bypass working right.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: daniel2002p
Date Posted: February 26, 2004 at 8:05 PM
on the 555l make sure that the passlock ground is hooked up in the right place.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
