2000 intrepid single wire door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27348
Printed Date: April 01, 2026 at 12:28 AM
Topic: 2000 intrepid single wire door locks
Posted By: lazyike
Subject: 2000 intrepid single wire door locks
Date Posted: February 27, 2004 at 5:02 PM
I installed a crimestopper rs-999tw1 in a 2000 dodge intrepid and put resistors in for the door lock.
Now she blew a fuse and I beleive a resistor is burnt up.  I ordered a power lock moduel from crimestopper but I still have to put in resistors.  The problem is I cannot find the values I need for lock and unlock.
Has anyone else had problem with chrysler cars "what a pain"?
Posted By: draasch
Date Posted: February 27, 2004 at 5:30 PM
you can use more then one inline. you should be able to get pretty close with just one..
here is what i have...
Power Lock WHITE/ D GREEN 16 PIN CONN. IN ACCESS HOLE ** #217
Power Unlock SINGEL WIRE SYSTEM IN DRIVER KICK OR HIGH IN DR. KICK
**Doorlocks Require +12v Pulse Thru 2.7k Ohm Risitor For Lock And +12v Pulse Thru 620 ohm Resistor For Unlock Wire Color Is WHITE/ DARK GREEN
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: lazyike
Date Posted: February 27, 2004 at 7:55 PM
draasch.
you list two diffrent spots for the one wire system "lock @16 pin conn" and unlock "in driver kick"
am I wrong to assume that you could just hook both lock and unlock to the same whit/d green wire in the drivers kick panel?
I am trying to figure why I blew a fuse and fried the resistors I was using.
I did wire multiple resistors to get the values you listed
thanks
Mike
Posted By: Velocity Motors
Date Posted: February 27, 2004 at 10:52 PM
Did you use a positive pulse to this wire ??
Posted By: lazyike
Date Posted: February 28, 2004 at 12:16 AM
yep.  used crimestoppers 6600-dlm
now I am thinking I should just order ch-lk2 and be done with it.  (this car does not have the sentury key)
Posted By: lazyike
Date Posted: February 28, 2004 at 12:18 AM
one more thing is the system worked fine for a week.
