2000 Caravan, 2100 series astrostart
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27394
Printed Date: March 31, 2026 at 11:57 PM
Topic: 2000 Caravan, 2100 series astrostart
Posted By: murraymurray
Subject: 2000 Caravan, 2100 series astrostart
Date Posted: February 28, 2004 at 1:14 PM
Hi Guys Great site I am looking for installiation tips on installing a 2100 series astrostart in a 2000 dodge caravan . I also wonder istead of  using  resistor can I triger the relays as they really easy to get at for the locks. This van has no security system and no security key. But it has keyless entry.
  Thank You
   Murray
murraywatchel
Posted By: mxxmikexx
Date Posted: February 28, 2004 at 4:15 PM
yes you can do it by triggering the factory relays
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Date Posted: February 28, 2004 at 5:32 PM
Does anyone have the instaliation tips on this one Ex wire colors and any other tips to help me along with this install. or is it the same as a 98 caravan which I have done before.
Thank you Murray
murraywatchel
Posted By: Velocity Motors
Date Posted: February 28, 2004 at 5:55 PM
Do a search in this forum and you will find everything needed. This is a common vehicle worked on and there is alot of information available.
Date Posted: February 28, 2004 at 6:05 PM
Audiovox Tech Support 1852 FaxBack ID:
DODGE CARAVAN 2000 MINIVAN
Security Color Polarity Location
Battery RED (+) IGNITION SWITCH HARNESS
Ignition 1 DARK BLUE (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger BROWN / WHITE (-) LOWER RIGHT GRY CONN AT FUSEBOX
Trunk Trigger TAN/BLACK (-) 40 PIN CONN AT FUSE BOX
Hood Trigger BROWN (-) PIN UNDER HOOD IN SOME VEHICLES
Alarm Disarm WHITE/ DARK GREEN (-) NEG PULSE W/665 OHM RESIS. AT FUSE PANEL
Alarm Arm WHITE/ DARK GREEN NEG PULSE/NO RESISTOR AT FUSE PANEL
Parking Lights LIGHT GREEN / WHITE (-) HEADLIGHT SWITCH HARNESS LEFT OF COLUMN
Remote Start
Ignition 2 DARK GREEN/ RED (+) IGNITION SWITCH HARNESS
Ignition 3 (+)
Accessory 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
Accessory 2 (+)
Anti-Theft Descript NONE
Key Sense LIGHT BLUE (-) IGNITION SWITCH HARNESS
Neutral Safety BLACK/ WHITE (-) AT POWER CONTROL MODULE
Tachometer GRAY/RED (-) OR BLU/TAN PCM COIL 2.4 L ENG. SEE NOTE
Speed Sense WHITE/ ORANGE (AC) BLK 40 PIN CONN DR.FRT.QRT.PIN 66 AT ECM
Brake Lights WHITE/ TAN (+) AT BRAKE SWITCH
Reverse Lights VIOLET/BLACK (+) BLK 10 PIN CONN DR.FRONT OF ENG
Horn BLACK/ RED STEERING COLUMN HARNESS
Doorlocks/Windows
Power Unlock WHITE/ DARK GREEN (-) WHT PLUG B58 CONN 250 OHM RESISTOR OR BC
- Note USE 1500 OHM RESISTOR WITH FACTORY ALARM/250 OHM WITHOUT
PowerLock WHITE/ DARK GREEN (-) BCM AT FUSE BOX 1500 OHM RESISTOR OR BCM
- Note USE 4020 OHM RESISTOR WITH FACTORY ALARM/665 OHM WITHOUT
Driver Mtr Unlock VIOLET / YELLOW (+) JUNCTION BLOCK
Driver Mtr Lock BROWN (+) JUNCTION BLOCK
LF Window Up LF:LIGHT GREEN
RF Window Up RF:BROWN LR:BLUE
RR:GRAY
LR Window Up LF:WHITE
RR Window Up RF:VIOLET LR:RED
RR:DARK GREEN
Convenience
Headlights-Lo GREEN/ ORANGE (+) LIGHT SWITCH
Wipers-Lo PINK/VIOLET (+) WIPER SWITCH
Modules
Module 1 BEHIND GLOVE BOX UNDER DRIVERS DASH
Audio/Mobile Video
Battery PINK (+) RADIO HARNESS
Accesory RED / WHITE (+) RADIO HARNESS
Ground STRAP (-)
Illumination BLACK / YELLOW (+) RADIO HARNESS
LF Speaker (+) GREEN
LF Speaker (-) BROWN / RED
RF Speaker (+) VIOLET
RF Speaker (-) BLUE/RED
LR Speaker (+) BROWN / YELLOW
Mike Battaglia
Date Posted: February 28, 2004 at 8:21 PM
mxxmikexx: Your webpage doesn't load up for me ?? ( www.specializedcaraudio.com ) Just thought I'd let you know.
Date Posted: February 29, 2004 at 5:08 PM
yeah, im in the process of changing everything on it. thanks tho.
Mike Battaglia
