2002 Cavalier Passlock II Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27414
Printed Date: April 01, 2026 at 7:34 AM
Topic: 2002 Cavalier Passlock II Help
Posted By: timsshadow
Subject: 2002 Cavalier Passlock II Help
Date Posted: February 28, 2004 at 9:38 PM
Can anyone help me in the steps required to install a 555 bypass module for a 2002 Cavalier.  I have basic knowledge of installs (more car audio than security) but I would appreciate any help anyone can give me.  the instructions are not a lot of help.  I do have a RS that does work, but the anti-theft kicks in and shuts the car down.  Please be as specific as possible if you can.  I found the Yellow resistance wire (that one I know is right) but I am having difficulty finding the right black wire....
To Get Someone's Attention, You Can't Merely Tap Them On The Shoulder, You Have To Hit Them With A Sledgehammer.
Posted By: daniel2002p
Date Posted: February 28, 2004 at 10:21 PM
ok lets see,
cut the yellow wire in half and hook up the yellow wire form the bypass unit to the ignition side of the cars passlock wire and the BLACK / YELLOW to the ground side of the cars passlock wire.  the black wire goes to the BLACK/ orange that is under the dash, just tap it in, do not cut this one, and finally, the pink wire goes to ignition.  that should do it.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
one more thing.  take the lack wire and hook it up to the third ignition in your alarm, and the red to constant 12v.
    1.8L VVT-i I-4
