2001 Dakota Door pins
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27420
Printed Date: April 01, 2026 at 12:45 PM
Topic: 2001 Dakota Door pins
Posted By: dakota__1
Subject: 2001 Dakota Door pins
Date Posted: February 28, 2004 at 10:28 PM
Just installed a alarm in my truck.  All is good but my door pin connections.  I have different pins for each door,  figured out how to diode isolate each.  The problem is that I get neg. feed when door is open, and no feed when door is closed, but about a 30 seconds later when the door is still closed it becomes negative again.  This of course trips the alarm.  I tried the dome light, but have a delayed turn of time for the dome light.  How do I get the door switches working?  Must be a wire that doesnt change state somewhere!
Posted By: draasch
Date Posted: February 28, 2004 at 10:37 PM
Dome Light YELLOW (-) AT CENTRAL TIMER MODULE
* Central Timer Module Located In Drivers Kick Panel.(Dr Door TAN (-) All Others TAN/RED (-).
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: February 28, 2004 at 10:43 PM
I know the wire locations and colors, but they dont work because of delayed dome light on door close and a returning negative @ the door pins.
Posted By: draasch
Date Posted: February 28, 2004 at 10:50 PM
did you make your connection at this point????
Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: February 28, 2004 at 11:01 PM
Yes, made those connections.  Still gets negative after 30 seconds.
Posted By: draasch
Date Posted: February 28, 2004 at 11:07 PM
i have never had that prob before....is there a light under the dash that you can use????? have you considered going to the domelight itself????
how about where it comes out of the CTM???
Good Luck
David
Ace Security
813-376-9778
Tampa
