help me install Viper 550esp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27421
Printed Date: April 01, 2026 at 3:49 PM
Topic: help me install Viper 550esp?
Posted By: dtom4
Subject: help me install Viper 550esp?
Date Posted: February 28, 2004 at 10:32 PM
Newbie just bought a 550esp from a friend who had it sitting around for a while and never installed. I want to install it in my wifes 87 Saab 900. I know my way around cars pretty well but not that great with electronics. It didn't come with the installation instructions so I downloaded it from DEI's web site. After going over it completely I'm not sure I didn't bite off more than I can chew. Would you guys be nice enough to walk me through a few things if needed?
Also looking at the installation guide it appears there are some differences between what they show and what I have. The brain in the instructions are plugged by the wiring harness on 3 sides and has jumpers. Mine is only designed with the harnesses pluging intoone side and have no jumpers. Also there are a few little differences in the wire coloring. I assume I have an older model unit? I think I can work with the current instructions but Is there any way of getting the correct ones? Also is there a source to get the wiring diagram for the 87 Saab?   TIA
Dave T.
90 4Runner
93 Civic DX
86 TransAm
87 Saab 900
93 Lumina Z34
81 280 ZX
Posted By: draasch
Date Posted: February 28, 2004 at 10:48 PM
the listing that i have says a 9000. it might be a typo. did they even make a 9000????
here is what i have....
Make:   Saab
Model: 9000
Year:    1987-93
This Database Was Last Updated On:    6/9/2003
Index #: 5796
Alarm
Constant 12 volts GRAY AND GRAY IGNITION SWITCH HARNESS
Ignition 12 volts GREEN / WHITE IGNITION SWITCH HARNESS
Starter YELLOW/WHITE IGNITION SWITCH HARNESS
Dome Light BLACK (-) PASSENGER PIN SWITCH
Trunk Pin Switch BROWN (-) AT TRUNK PIN SWITCH OR OEM ALARM *
Parking Lamp GREEN/ RED (+) AT LIGHT SWITCH OR AT FUSE BOX
Power Lock ADD ACTUATOR ACTUATOR NEEDED IN DRIVER DOOR #204
Power Unlock ADD ACTUATOR ACTUATOR NEEDED IN DRIVER DOOR #204
#204- See Adding Actuator Door Lock Diagram. * OEM Alarm Module Located Behind Passenger Dash.
View Diagrams
Accessories
Window Up D\ RED / WHT P\ BLK/WHT @ MAIN
Window Down R/ GRN S/ BLU SWITCH #211
Ign Key Warn
Trunk Release
OEM Horn YELLOW (-) STEERING COLUMN HARNESS
Headlights
OEM Alarm Arm
OEM Alarm Disarm RED (-) AT OEM ALARM MODULE BEHIND PASS. DASH
#211- See Reversal Rest At Ground Power Window Circuit Diagram.
View Diagrams
Remote Start
Tach Signal BLUE UNDER DRIVERS SEAT
Ignition #2 GREEN / WHITE IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory GRAY/WHITE IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light GRAY OR WHITE (+) AT SWITCH
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: dtom4
Date Posted: February 28, 2004 at 11:08 PM
David:
Thanks for the information. They did make a 9000 with some years overlapping. Mine is a 900 and I would presume the wiring is probably pretty similar. I can try and piece everything together and see if I can get it to work. Appreciate the help.
Dave T.
90 4Runner
93 Civic DX
86 TransAm
87 Saab 900
93 Lumina Z34
81 280 ZX
Posted By: draasch
Date Posted: February 28, 2004 at 11:10 PM
always test with a meter first, i do have the info for a hard top 86-91 i'll send it to you.......
Make:   Saab
Model: 900 Conv. & Hardtop
Year:    1986-91
Index #: 832
Alarm
Constant 12 volts GRAY IGNITION SWITCH HARNESS
Starter YELLOW/RED OR YELLOW IGNITION SWITCH HARNESS
Dome Light BLACK (-) AT PASSENGER PIN SWITCH
Trunk Pin Switch BLACK (-) AT TRUNK LIGHT OR SWITCH
Parking Lamp GREEN/ RED (+) AT LIGHT SWITCH OR FUSE BOX
View Diagrams
Accessories
Window Up D\ RED / WHT P\ YEL/RED D\ GRN/WHT P\ GRY/WHT @ MAIN
Window Down F/ BLK/WHT F/ BLU/WHT R/ GRN/RED R/ RED / WHT SWITCH #211
Ign Key Warn GREEN (+) STEERING COLUMN HARNESS
Trunk Release N/A
OEM Horn BLACK (-) STEERING COLUMN HARNESS
Headlights YELLOW (+) AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm Disarm
#211- See Reversal Rest At Ground Power Window Circuit.
View Diagrams
Remote Start
Tach Signal BLUE AT COIL OR TEST CONNECTOR
Ignition #2 GRAY/WHITE IGNITION SWITCH HARNESS
Ignition #3 N/A
Brake Light RED (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light WHITE (+) AT SWITCH BELOW CONSOLE
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: dtom4
Date Posted: February 29, 2004 at 4:15 PM
Draasch, THANKS!!!! You da man. That should save me lots of time figuring out the car wiring. Now I can just tap the correct alarm wire to the car wire. Not sure what #204 actuator for the door locks though. Is that a relay? Also nor clear on what ignition  #2 is. Thanks again.
Dave T.
90 4Runner
93 Civic DX
86 TransAm
87 Saab 900
93 Lumina Z34
81 280 ZX
