Remote start in 94 Accord / Manual
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27426
Printed Date: April 01, 2026 at 6:40 PM
Topic: Remote start in 94 Accord / Manual
Posted By: speedylt
Subject: Remote start in 94 Accord / Manual
Date Posted: February 29, 2004 at 12:10 AM
I am going to attempt to install a remote starter in a 94 Honda Accord LX V6 4 door with a manual transmission. I have installed several remote starters before, but never in a manual transmission vehicle. Is there a safe way to make sure the vehicle is in neutral when it is started. I see several companies offer remote starters for manual transmission vehicles, but am not sure how they work.
Thanks,
Leonard
Posted By: laren5
Date Posted: February 29, 2004 at 4:34 AM
Get the Clifford G5 line with intellistart IV,    Works perfectlty with manual transmission.     Befor you get out of the car and before you turn off the ignition, you must put  the manual transmission in neutral, set the parking brake (this is how you would normally park a car), and then push a button on the "remote".    The alarm will take over the car.    You just switch off the car and take out the key and to your surpise the car keeps running with no key in it (the alarms takes care of this).   You step out of the car and close the door .   then arm your  car through the remote.
You can then safely remote start your car.     If for some reason your car aarm has been tripped or they have opened a door, then the alarm knows that it is not safe to do a remote start.
Works like a charm
Clifford Alarms
Posted By: laren5
Date Posted: February 29, 2004 at 4:36 AM
Sorry :
After you arm your car, the vehicle will automatically shut down and be prepared for remote start.
Clifford Alarms
Posted By: Velocity Motors
Date Posted: February 29, 2004 at 10:06 AM
You have to bypass the clutch wire for this vehicle.
Negative Clutch Bypass Circuit
The Honda uses a (-) type clutch activation system that requires you to wire in a relay to activate this circuit only during remote start. Use your (-) when running wire to activate the relay.
Posted By: speedylt
Date Posted: March 01, 2004 at 12:22 AM
Thanks for the info. I'll see if I can get ahold of the Clifford model you mentioned. Laren5, do you sell these?
If so, please contact me at ltennyso@hotmail.com
Thanks,
Leonard
Posted By: ers1121
Date Posted: March 03, 2004 at 7:37 PM
I have used both UltraStart and DesignTech for manual transmission vehicles and I prefer the UltraStart. 1250M. You set the parking brake and stepn the brake pedal twice. When turn off the key the vehicle stays running, after exiting the car and shutting the door the vehicle turns off. This assures that it is in neutral, if you open the door after that you will cancel the remote mode.
Ed
