creating an aux output?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27461
Printed Date: April 04, 2026 at 6:37 AM
Topic: creating an aux output?
Posted By: dmangru01
Subject: creating an aux output?
Date Posted: February 29, 2004 at 6:28 PM
My alarm does not have an aux output that is activated when the alarm is armed. I would like to hook up a window roll up module so that when the alarm is armed the windows will roll up also. Could I tap into a wire to give a signal when the alarm is armed? If so, which?  (I was thinking the wire that goes to the relay for the starter kill?)
thankx
Posted By: bassop823
Date Posted: February 29, 2004 at 8:55 PM
I just done a 530t on a dei alarm and the wire I used for my ground was the starter kill and everything worked fine. I beleive that is what most of the guys are using for the 530t.
bassop
