dual stage door locking on Highlander 03
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27519
Printed Date: April 03, 2026 at 4:12 AM
Topic: dual stage door locking on Highlander 03
Posted By: markcars
Subject: dual stage door locking on Highlander 03
Date Posted: March 01, 2004 at 3:03 PM
Does anyone know how to make the Toyota Highlander 03 have the same feature as the factory remote?. If you press unlock once, only the driver door opens. Upon pressing unlock a second time within 5 seconds all doors unlock. How can that be done with an aftermarket alarm? Will just 1 relay and two diodes do or do I need some more stuff for the dual stage locking/unlocking?
Also will the buzzer sound, signifying "door ajar" and not lock unless alldoors are locked? (with the aftermarket alarm?)   I read on a closed topic about this but had two ways, but only the easy way was posted. I want to know the other way with maximum features.
Posted By: profuse007
Date Posted: March 01, 2004 at 3:42 PM
1.i notice DEI makes this feature. the normal unlock wire goes the driver (**A) doorlock motor. then another unlock wire which comes from maybe a programable aux wire to do 2nd unlock which tie to the main(**B) unlock wire.
(**A)|     UNLOCK MOTOR|blue/red            |   |17 pin plug, pin 2 @ BECU *1|
(**B)|     POWER UNLOCK|document #1070      |   |
link for doc #1070
*1 The BECU (Body ECU) is behind the glove box, it is the module to the right.
2.understand where ur question but cant help you...sorry
Houston,TX
Posted By: markcars
Date Posted: March 01, 2004 at 4:15 PM
Doc 1070 is the perfect answer to what I am looking for. Got to try it. Thanks.
