What Karr do I have
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27723
Printed Date: March 31, 2026 at 4:15 AM
Topic: What Karr do I have
Posted By: Nebuchabnezzer
Subject: What Karr do I have
Date Posted: March 04, 2004 at 2:24 PM
My sistere kiss the back end of a bus. The good news is that every one on the bus and my sister are fine, but the bad news my the car R.I.P. We bought the car used so someone euls put the alarm in and I am gong to try and save some money and huck this alarm in the new car. The olny nember that I see on the back read as the floowing "DEALER INITAISL:______________ TECH#:14 STOCK#____________ LAST 8 VIN:___________________ REV: 00 With this info can you tell me what modile number this is. It DOES NOT HAVE AUTO START, if the helps. 13 pin main harnes and the reg side huckups for shock, kill botton, LED, &lock wire. If you can tell the molder that I have I also needed the Wiring Diagram it you can find it. If not I can look around Thanks Nebuchabnezzer ------------- Never understimate the predictability of stupidity!!!!!!!!!!!!
Date Posted: March 04, 2004 at 2:26 PM
Ps Sorry for the spelling errors ------------- Never understimate the predictability of stupidity!!!!!!!!!!!!
Posted By: daniel2002p
Date Posted: March 04, 2004 at 11:11 PM
Unfortunantely that does not tell me nothhig at all. bit more specific???
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Date Posted: March 05, 2004 at 2:33 AM
The only more specific i can get it is is in a little black box. give my time to rip off all the tape off the wires and I can tell you the coloe codes and the size wires? will that help?? There is nothing ealu on the alarm itself that tells me what it is? ------------- Never understimate the predictability of stupidity!!!!!!!!!!!!
Posted By: jfk51502003
Date Posted: March 05, 2004 at 1:11 PM
HEY DOES IT SAY ...KARR...ANYWHERE...IF SO IT IS AN AUDIOVOX....NOT IN PUBLIC DEALERSHIP ITEM ONLY...HOPE IT HELPS
Date Posted: March 05, 2004 at 9:52 PM
I have talked around to people and they said that if it says KARR on it it is a dealer accsoory and is not available to public. hope this helps.
1.8L VVT-i I-4
Date Posted: March 06, 2004 at 11:50 PM
Damn this does not help me out a bit. I am starting to think if it any thing like a DEI prodice, do you think the wire codes would be the same??? Deos any one have the wire code for any of the KARR alarm?? If i try that and the alarm blows up then there is no mony out of my pocket but my sisters. and no it does not say karr on the brain it says "KARR", it clearly states this on the key chaine and and onto of the alram brain ------------- Never understimate the predictability of stupidity!!!!!!!!!!!!
Date Posted: March 07, 2004 at 6:52 AM
could not tell you the color codes as stated before only dealers know them.
1.8L VVT-i I-4
Date Posted: March 07, 2004 at 10:14 PM
Damn this sucks ------------- Never understimate the predictability of stupidity!!!!!!!!!!!!
Posted By: serialthrlla
Date Posted: March 07, 2004 at 10:44 PM
sounds like your better off buying a new one, besides installing an alarm that has already been installed sucks.
Date Posted: March 08, 2004 at 12:01 PM
(serialthrlla) not realy, the wires are pre-set for me to run, taped very niceley and I have do them before for my friends. Now if the cut the wire to short then I would just throw the damn thig away ( which I have already done now since there is now way i can huck up the wires) and i am getting a clifford alarm (not DEI verson)
