Programming Tach
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27884
Printed Date: April 03, 2026 at 2:34 AM
Topic: Programming Tach
Posted By: cordoba360
Subject: Programming Tach
Date Posted: March 07, 2004 at 1:01 PM
ok guys simple and to the point  94 Gmc truck ( gas ) and audiovox aps-786
i havent programmed the tach yet , but when is the best time to program it
when the engine is good and warm, and program with a low rpm (700 rpm)
or with a cold engine with a high rpm (1100 rpm)
thanks in advance , you been a great help
Posted By: JakeJ
Date Posted: March 08, 2004 at 12:39 AM
   Most of the time it will not make a diference but I would program it under the sercumstance that it will be used most. Most of the RS that I install will be used primarely in the cold morning so I try to program it for that kind of start.
Wyoming 12volt Enthusiast
