2-Way FM
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2797
Printed Date: April 01, 2026 at 8:28 PM
Topic: 2-Way FM
Posted By: TheRapture
Subject: 2-Way FM
Date Posted: August 15, 2002 at 8:31 AM
Ok, in a couple of previous postswe all talked about how to extend the range on a 2-way FM tranmitter... 1 way was to put it in the upper part of the bezel INSIDE of the dash, but away from metal and wires... i tried this, and have gotten SHORTER range and FALSE signals!!! another way was to take the transmitter out of it's casing and putting it into the head liner of the car near the windshield (note: i do not have tint in the upper part of the windshield) questoin is... HOW do i put it up into the head liner?... does the liner just pull down or what? or does someone have a diffrent way to get better range? by the way, for reference, i have a '97 Acura Integra GSR
Posted By: Velocity Motors
Date Posted: August 15, 2002 at 8:51 AM
Depending on how large the antenna is you can easily pull back the roof liner about 1/2" to slip the antenna into the liner. I think the liner you have is a plastic one which makes it a little harder. If your car has the carpeted one then it's a breeze to pull back a little bit. ------------- Jeff
Date Posted: August 15, 2002 at 8:56 AM
yes, it's plastic... do i wedge a screwdriver (or something with a flat edge) up into the liner whereit curvers into the windshield.... then shove the circuit board in?
Date Posted: August 15, 2002 at 9:00 AM
Usually I can use my finger tips to do it. A screwdriver may cause a bad wrinkle to apper because of it's small surface area . If you use your 4 fingers and pull it away it should pull back about 1/2" or so.... enough to quickly shove the antenna through. ------------- Jeff
Date Posted: August 15, 2002 at 9:11 AM
what do i do wih the plastic antenna though?... face it down the window? i.e. the case protecting the circuit board is off, but the rubber 4" antenna is still connected to the board
Date Posted: August 15, 2002 at 10:23 AM
I usually have it parallel with the liner and the windshield so that if you look hard enough you can see the antenna but it won't be noticable otherwise. ------------- Jeff
Date Posted: August 15, 2002 at 10:31 AM
gotcha... i'll try it out and let you know how the range is... there is NOT any metal or wires up there to screw up the signal... right?
Date Posted: August 15, 2002 at 10:35 AM
Just the roof but I have done this on many vehicles and it seems the best place for range as it is the highest place without any EMI. ------------- Jeff
Date Posted: August 15, 2002 at 11:34 AM
well... i jst tried pulling the little black rubber lip back, then pulling the roof liner down to fit it in... it wont budge, what should i do?
Posted By: jorgefdz
Date Posted: August 15, 2002 at 12:19 PM
Hi. I put my aladdin receiver in the top of my windshield glass, is it correct? I paste it with jettisonable tape. is it ok? ------------- J.F.L.L.
Posted By: cpgoose
Date Posted: August 15, 2002 at 12:40 PM
Did you unscrew the visor? My visor holds the roof liner in pretty tight.
Date Posted: August 15, 2002 at 1:02 PM
well... i was pulling at the roof liner right above the mirror.... so no visor screws are even around it. hmmm?
Date Posted: August 15, 2002 at 1:07 PM
It will be very rigid because it's attached onto the roof by friction fitting it on. You may need use something to pry it with but make sure that it's wide enough that it won't cause a wrinkle in the roof liner. ------------- Jeff
Posted By: Ryan McFadden
Date Posted: August 28, 2002 at 11:04 PM
How do you like the Aladdin product?
