99 accord installing and security system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28027
Printed Date: April 07, 2026 at 4:35 AM
Topic: 99 accord installing and security system
Posted By: 99acc0rd
Subject: 99 accord installing and security system
Date Posted: March 08, 2004 at 10:53 PM
hi this is my frist time installing and security on a car it a 99 honda accord lx the security system is alarm and keyless entry my question is on the wiring diagram it does not show me anything about where the door trigger + is it does show me where the door trigger - is but i need the + so can anyone please help me out and tell me where i can find that at.
            this is the wiring diagram for my car as u can see it just tell me where the door trigger - is .
1999 Honda Accord Security Information
Constant 12V+ White  Ignition Switch Harness
Starter BLACK/ White  Cut after Fuse Panel, not at Ignition Switch
Ignition BLACK / YELLOW  Ignition Switch Harness
Ignition 3 WHITE/ Black  Power this or ABS Light on Remote Starter
Accessory Yellow  Ignition Switch Harness
Tach Blue  Distributor
Brake Switch GREEN / WHITE  Brake Switch
Trunk Release WHITE/ Red (+)  Driver's Kick Panel
Trunk Pin ORANGE / Silver Dots  Driver's Fuse Panel in A 2 Pin Connector
Parking Lights RED / Black (+)  Connector at Fuse Panel Driver's Side
Head Lamp Blue/Red (-)  Steering Column
Factory Disarm w/Locks  On EX Model
Door Trigger BLACK/ White (-)  Passenger's Fuse Panel Green 4 Pin Connector
Door Lock BLACK/ Blue (-)  On Passenger's Side, Light Green Connector
Door Unlock Orange (-)
Driver's Lock WHITE/ Red  Driver's Fuse Panel
Driver's Unlock Yellow (EX)  Or GREEN/ Red on(LX) Model Fuse Panel
Passenger Unlock GREEN/ Red  With Power Lock Wires
Horn Wire GREEN/ Blue (-)  Green 4 Pin Connector Passenger's Side Fuse Panel
Windows Up LF=RED / Yellow, RF=Blue/White, LR=RED / Yellow, RR=RED / Yellow
Windows Down LF=RED / Blue, RF=Blue / YELLOW, LR=RED / Blue, RR=RED / Blue
Posted By: rknj01
Date Posted: March 09, 2004 at 12:13 AM
use a relay, or get an alarm made by DEI
