Wirng Diagram & Security
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28145
Printed Date: April 04, 2026 at 6:48 PM
Topic: Wirng Diagram & Security
Posted By: Rrxpaul
Subject: Wirng Diagram & Security
Date Posted: March 10, 2004 at 9:12 PM
Does anyone have the wiring diagram for 2004 Toyota 4 Runner?
Posted By: wblakes
Date Posted: March 10, 2004 at 10:07 PM
12volts- WHITE/ blue and red    +ignition harness
Starter- GREEN/ black       +ignition harness
Ignition- BLACK/ red       +ignition harness
Second Ignition- blue / YELLOW       +ignition harness
Accessory- WHITE/ green       +ignition harness
Keysense- GREEN/ YELLOW       - ignition harness
Power Lock- blue       - driver kick, 18 pin plug
Power Unlock- green (2 pulse) -driver kick, 18 pin plug
Lock Motor- blue/red to BLACK/ white       5wi driver kick, 13 pin plug
Unlock Motor- blue/black to BLACK/ red       5wi driver kick, 13 pin plug
Parking Lights+      green       +       left of fuses, 16 pin plug
Parking Lights-      green       -       pin 8, top plug at BECU
Hazards- white       -       hazard switch
Door Trigger- purple / YELLOW      -pin 12, top plug at BECU
Dome Supervision- white      -plug to right of fuses, pin 8
Trunk/Hatch Pin- GREEN/ YELLOW       -back door ECU in hatch
Hood Pin- pink/green       -driver kick, blue 18 pin plug
Factory Alarm Arm- arms with lock
Factory Alarm Disarm- disarms with unlock
Disarm No Unlock- use key sense wire
Tachometer- BLACK/ white       pin 5, conn. E8 at ECM
Brake Wire- GREEN/ YELLOW +left of fuses, 16 pin plug
Parking Brake- lt. green -pin 2, middle plug at BECU
Horn Trigger-GREEN/ red       -steering column
Posted By: Rrxpaul
Date Posted: March 10, 2004 at 10:23 PM
Thanks a Million WBlakes
Posted By: wblakes
Date Posted: March 10, 2004 at 10:24 PM
not a problem, glad i can help
