wire diagram for 02 kia spectra
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28291
Printed Date: April 01, 2026 at 7:26 PM
Topic: wire diagram for 02 kia spectra
Posted By: kustomsoundsiv
Subject: wire diagram for 02 kia spectra
Date Posted: March 13, 2004 at 2:47 AM
i need to find a diagram for my gurls 02 spectra so i can hook up the alarm can anybody hook me up please
Posted By: mxxmikexx
Date Posted: March 13, 2004 at 3:18 PM
Audiovox Tech Support 7873 FaxBack ID:
KIA SPECTRA 2002 4DR HATCHBACK
Security Color Polarity Location
Battery RED OR BLACK (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/ BLUE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger LIGHT GREEN/ RED (-) DKP IN WHITE 18 PIN PLUG
Trunk Trigger GREEN/ YELLOW (-) DKP IN WHITE 18 PIN PLUG
Parking Lights PINK/BLACK (+) DKP IN WHITE 18 PIN PLUG
Low Crr Pk Lights GREEN HEADLIGHT SWITCH
Remote Start
Ignition 2 WHITE (+) IGNITION SWITCH HARNESS
Accessory 1 GREEN (+) IGNITION HARNESS
Anti-Theft Descript NONE
Neutral Safety BLACK/ RED (+) CLUTCH SWITCH
Tachometer YELLOW/WHITE (AC) PLUG ON STRUT TOWER
Speed Sense ORANGE / BLACK (AC) PIN 42 @ BCM,UNDR CNTR CON, RGT GAS PEDA
Low Crr. Pk Lights GREEN HEADLIGHT SWITCH
Brake Lights RED / BLACK (+) BRAKE PEDAL SWITCH
Reverse Lights BLUE/BLACK (+) BACK OF INSTRUMENT CLUSTER
Horn GREEN/ ORANGE (-) STEERING COLUMN
Doorlocks/Windows
Power Unlock SAME
PowerLock ADD TUATOR (AC) IN DRIVER DOOR
LF Window Up LF:RED (REV)
RF Window Up RF:RED / YELLOW LR:RED / BLUE
RR:RED / WHITE
LR Window Up LF:GREEN (REV)
RR Window Up RF:GREEN/ YELLOW
LR:BLUE/WHITE RR:GREEN / WHITE
Convenience
Headlights-Lo RED / BLACK (+) BOTTOM OF STEERING COLUMN
Wipers-Lo BLUE/BLACK (+) BOTTOM OF STEERING COLUMN
Audio/Mobile Video
Battery BLUE/RED (+) RADIO HARNESS
Accesory BLUE/BLACK (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED / BLACK (+) RADIO HARNESS
LF Speaker (+) BLACK / YELLOW
LF Speaker (-) BLUE/ORANGE
RF Speaker (+) BLUE/GREEN
RF Speaker (-) YELLOW/RED
LR Speaker (+) GREEN/ RED
LR Speaker (-) GREEN/ BLACK
RR Speaker (+) BLUE/WHITE
RR Speaker (-) RED / BLUE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Documents
700064 POLARITY CONVERTER
------------- Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
