Viper owner & Pros.Please help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28292
Printed Date: April 01, 2026 at 5:54 PM
Topic: Viper owner & Pros.Please help
Posted By: cargovan
Subject: Viper owner & Pros.Please help
Date Posted: March 13, 2004 at 3:02 AM
when the eng .turn off ,the 2 front do not unlock automatticly but the back &sliding side do
when start the eng. all door lock
it's a 04 chevy express.the alarm is viper 791.
the  alarm was set up as follow;
    LOCK       button on the remote ( lock all dood)
    UNLOCK ...................................     ( unlock rear & sliding )
     AUX .................................................(press for more than 1 sec. 2 front open)
      LOCK & UNLOCK ...................     (  AT the same time .remote start )
Posted By: kgerry
Date Posted: March 13, 2004 at 10:55 AM
well unless you changed the factory configuaration pressing lock and unlock together is activating timer mode, not RS.  RS is activated by pressing the snowflake button ( * ) two times.....
also, AUX is a delayed validity channel and you have to hold it for about 4 secs. to activate this channel.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Teamrf
Date Posted: March 13, 2004 at 11:08 AM
Make sure you have the engine controlled door locks on in the alarm settings.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
