1990 gmc truck 3500 2 door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28307
Printed Date: April 01, 2026 at 6:54 AM
Topic: 1990 gmc truck 3500 2 door
Posted By: dinothedog
Subject: 1990 gmc truck 3500 2 door
Date Posted: March 13, 2004 at 5:01 PM
I NEEDTO KNOW IF THERE IS A FACTORY RELAY FOR THE POWER WINDOWS AND WHERE IT'S LOCATED
Posted By: draasch
Date Posted: March 13, 2004 at 6:09 PM
what are you looking to do????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: March 13, 2004 at 6:49 PM
install a clifford alarm! but the alarm about ten years old
Posted By: draasch
Date Posted: March 13, 2004 at 7:50 PM
are you doing window roll up????? or do you ust need the truck info?????
Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: March 14, 2004 at 9:50 AM
im sorry ,i need to know where the power door lock relay is and i dont see any wires for power door locks in the driver side kick panel or around speaker in the dash
Posted By: draasch
Date Posted: March 14, 2004 at 12:12 PM
there are no relays..........here is the info that you need...
Power Lock L BLUE BELOW DRIVER SPEAKER OR #203
Power Unlock BLACK/ WHITE DRIVER KICK PANEL
#203- See Reversal Rest At Ground Door Lock Diagram.
if you had a DLS, that would take care of the relal wiring. you would just have to wire up the wires in your truck...
https://wiringinstructions.com/203.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
