Alarm goes off while Truck is on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28490
Printed Date: March 29, 2026 at 4:06 AM
Topic: Alarm goes off while Truck is on
Posted By: SalemBird
Subject: Alarm goes off while Truck is on
Date Posted: March 16, 2004 at 3:30 PM
I have a 1994 chevy pu with a factory dealership installed alarm (Goodwrench GM). I ve had the alarm go off while Im driving I found a wire loose from the Module a pink ignition wire.You know when you start the truck the locks lock they don't now I think it is because of the pink wire being unplugged I can't find for the life of me to find were to plug it back in.It's not a long wire so it should be close.Any Help would be greatly appreciated
Posted By: draasch
Date Posted: March 17, 2004 at 6:10 AM
here is your info...the pink wire will go to the second listed wire marked ign. 12 volts...
Ignition +12 Volts:
PINK
IGNITION SWITCH HARNESS
------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: March 17, 2004 at 9:07 AM
Thanks I still can't find it. Facing the steering wheel is it on the left or right? Sorry to be so dumb.I thank you for the information!
Posted By: profuse007
Date Posted: March 17, 2004 at 10:00 AM
if youre to follow the key cylinder down to the main ignition wires, youll find that wire.
------------- Houston,TX
Date Posted: March 20, 2004 at 8:56 AM
Thanks the pink wire coming from the module at the end has a plug.I just can't find were to plug it in.When I turn my truck on my doors won't lock the alarm stays armed.Any Ideals were to plug it in.Thanks
