i need help with remote start on 2002 dodge ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2851
Printed Date: April 01, 2026 at 12:49 PM
Topic: i need help with remote start on 2002 dodge ram
Posted By: duece02
Subject: i need help with remote start on 2002 dodge ram
Date Posted: August 17, 2002 at 12:20 PM
Alarm works fine, all except for the remote start. I think its because of the tach. Can any one help me locate it?
Posted By: Velocity Motors
Date Posted: August 17, 2002 at 4:07 PM
  • ignition coil
  • coil pack
  • injector ( non common wire )
Go to any of these spots for a tach signal.
Posted By: iamdr7
Date Posted: October 22, 2002 at 3:57 PM
 am installing a remote start on a 2002 Dodge Ram pickup. The remote-start alarm harness for the remote start is:
Orange -----(+) Acc
Pink -----(+) Ign
Purple -----(+) Stater
Red ----- (+) 12v
Blue/Blk ----(-) Ignition 2
Yellow/ White -----(-) Acc2
One illustration suggested doing this:
+12 to 87
wire from RS to 85
+12 to 86
Vehicles Secondary Primary to 30
It will not run. It will crank over but. Any information would be appreicated. Also any information on hooking up the accessory (heat/ac). I know that I must be forgetting one wire or have something backwards.  Thanks
Posted By: kickyride
Date Posted: October 22, 2002 at 6:24 PM
The tach wire should be tan/red at the ignition coil. Don't forget to perform any tach programming that your system may have. Hope this helps.
Iamdr7,    First, your truck has 4 ignition wires that need to be powered up or there might be problems down the road. The factory service manual shows them as follows: IGN1-Blue 16ga, IGN2-RED / White 16ga, IGN3-Dark Green, IGN4-Orange. You're on the right track with your relay as long as your RS wire going to 85 is a negative ignition output. You'll need a relay for each additional ignition circuit.
Second, does your truck have a transponder type immobilizer? if so, your key should have a gray head and you will need to perform a transponder bypass. You can either use something like an Omega PASS-4 or DEI's 555L which both require an extra key or you can get an Omega DB-PKUCH module that interfaces with the vehicle's databus and doesn't require a key. If you can't find one locally, they are available on my site. Hope this helps.
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
