RS 2004 Toyota 4Runner
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28629
Printed Date: March 31, 2026 at 2:09 PM
Topic: RS 2004 Toyota 4Runner
Posted By: Rrxpaul
Subject: RS 2004 Toyota 4Runner
Date Posted: March 18, 2004 at 7:37 PM
I recently installed a Viper 650 on a 2004 4 Runner.  I can't get the RS to start the car.  RS engaged but car does not start.  I utilize a 555U with a coded key to bypass the immobiler. Note that car does RS with the key in the ignition.  What seems to be the issue here?
Posted By: draasch
Date Posted: March 18, 2004 at 8:03 PM
try to reprogram the bypass...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: Velocity Motors
Date Posted: March 18, 2004 at 8:20 PM
The 555U is VERY picky with the location of the key in the black box. Make sure that you reposition the key inside the box and try the remote start again. If it still doesn't start, try moving the key around until you find the sweet spot of the module. The module doesn't need to be programmed, just make sure that the transponder ring is tight around the cylinder and that the key is in the sweet spot.
Posted By: Teamrf
Date Posted: March 18, 2004 at 8:45 PM
Programming is off some...just like Jeff said play around with the "box" and see what you can come up with.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
