94 Eagle Talon alarm help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28776
Printed Date: May 13, 2026 at 10:16 AM
Topic: 94 Eagle Talon alarm help
Posted By: s2000vtc
Subject: 94 Eagle Talon alarm help
Date Posted: March 21, 2004 at 12:28 PM
I just finished installing an alarm in a 94 Eagle Talon Tsi/Awd. I tested all my connections and the alarm works fine but my 4 ways and turn signal indicators dont work but the turn signals are fine. Also my fuel, oil psi, and temp gauges are screwed up. Can someone please help me out here???
Posted By: Velocity Motors
Date Posted: March 21, 2004 at 4:36 PM
Disconnect the parking light wire from the alarm and see if the problems persist. If they go away, you need to isolate the parking out output of the alarm from the car with a relay. If the problem is still there, then what you have to so is remove wire one by one until the problem is not there.
Posted By: s2000vtc
Date Posted: March 22, 2004 at 2:51 PM
ok thanks. i tried disconnecting the wire to the parking lights and that didnt fix the problem. Any idea which other wires might cause this? I'd just like an idea where I should start.
Posted By: s2000vtc
Date Posted: March 22, 2004 at 4:43 PM
Thanks for all the help but I found the problem and now I feel really stupid. I disconnected a plug above my fuse box when I was installing the alarm and I never plugged it back in. Everything works fine now.
