2002 Ranger Avital 2300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28780
Printed Date: May 13, 2026 at 7:32 AM
Topic: 2002 Ranger Avital 2300
Posted By: dannyakarudy
Subject: 2002 Ranger Avital 2300
Date Posted: March 21, 2004 at 1:07 PM
I was wondering if this is a decent alarm and if so what all I'll need to install it on my 2002 Ranger FX4
Thanks,
Dan
Posted By: kgerry
Date Posted: March 22, 2004 at 9:29 AM
yes, it's a good little unit.... everything you need comes with
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: March 22, 2004 at 11:43 AM
I thought I would need to purchase a mercury switch for the hood?
Posted By: draasch
Date Posted: March 22, 2004 at 2:14 PM
you can use a pin switch
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: March 22, 2004 at 2:31 PM
How can I put some sort of a switch on the rear sliding window?
Posted By: kgerry
Date Posted: March 22, 2004 at 3:31 PM
any # of options, magnetic contact switch or FDS field disturbance sensor is what i'd use....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Date Posted: March 22, 2004 at 5:05 PM
Another question...  I was wondering if there was a way to have 2 different arming modes... for example - 1 that arms only the doors / window and hood switches, and one that arms all sensors.  Reason I ask is that I take my dogs with my places, and I'd hate to have the alarm go off because my dog is in the bed of my truck moving around.
Posted By: kgerry
Date Posted: March 23, 2004 at 9:24 AM
only way i can think of is to put a separate toggle switch to power off the shock/impact sensor, then only the door triggers would be active, that should be very easy to do.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Date Posted: March 23, 2004 at 10:00 AM
Aren't most of the shock sensors built into the brain unit though?  and how could I use 1 toggle switch for multiple zones?
Date Posted: March 24, 2004 at 9:47 AM
anybody?
Posted By: draasch
Date Posted: March 24, 2004 at 10:05 AM
most of the shock sensor are not buit into the main unit, they are add on..........
Good Luck
David
Ace Security
813-376-9778
Tampa
