2002 Tacoma v6 Tach wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28829
Printed Date: May 13, 2026 at 7:46 PM
Topic: 2002 Tacoma v6 Tach wire
Posted By: jclark319
Subject: 2002 Tacoma v6 Tach wire
Date Posted: March 22, 2004 at 8:56 AM
I have a Trilogix CS 423 remote starter system. I have successfully installed the keyless entry but cannot find the tach wire. I was initially told to look for a black wire in the 26 pin connector behind the glove box. There isn't one. I was also told to look for the black wire at the ignitor, there isn't one. Can anyone point me in the correct direction. Thanks
------------- JClark
Posted By: draasch
Date Posted: March 22, 2004 at 9:25 AM
i just sent you the info on that car ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: Velocity Motors
Date Posted: March 22, 2004 at 12:48 PM
Go to the injector wire at the top of the engine where the injectors are located. Use any of the uncommon colored ones.
------------- Jeff
Date Posted: March 22, 2004 at 3:00 PM
I found the ignitor last night. BUT I could not determine which wire it would be. I have recieved an email that says the GREEN/ black. Any ideas? If I must go into the engine compartment, I had rather go to the ignitor instead of the coils. Thanks alot for the info.
Posted By: cbag1
Date Posted: March 22, 2004 at 3:22 PM
DEI info: Lt. GREEN/ black at instrument cluster or On the V6 it is at the igniter on the passenger fender, below the air filter box. goodluck
Date Posted: March 22, 2004 at 3:26 PM
Will try it out tonight at work. Thanks alot!!!
Date Posted: March 23, 2004 at 8:24 AM
Keyless entry and remote start success. Thanks for the help. ------------- JClark
Posted By: draasch
Date Posted: March 23, 2004 at 8:27 AM
jclackis newbie gone pro! i bet his wife or girlfriend thinks he is DA MAN! lol ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: March 23, 2004 at 8:31 AM
I have an extinsive history in car stereo, speakers, amps and crossovers...just new to remote starters. WIFE knew already who was da man...lol
