door lock help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29031
Printed Date: April 07, 2026 at 4:35 AM
Topic: door lock help
Posted By: bigflareside
Subject: door lock help
Date Posted: March 25, 2004 at 6:47 PM
I have a 94 ford f150 ....installed a crime stoper superrage alarm with remote start........hooked up the doorlocks rev. polarity like the manual says ....and i get nothing when I hit the buttons.......any help would be aprecated
Posted By: boomer_106
Date Posted: March 25, 2004 at 9:02 PM
Sounds like you already have this info but, here it is so you can doublecheck your wiring. You will not that if it had factory keyless then its a positive system, if not then reverse polarity like you said. At any rate I would start by doublechecking the wiring.
Ford
Pickup F Series
1994-1995
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED / LIGHT BLUE
IGNITION SWITCH HARNESS
Ignition  #1:
RED / LIGHT GREEN
Ignition #2:
GRAY / YELLOW (# AWG)
IGNITION SWITCH HARNESS **
Ignition  #3:
GRAY / YELLOW-2WIRES
Accessory:
BLACK/ GREEN
IGN. SWITCH HARNESS
Brake  Light:
LIGHT GREEN
(+) AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
TAN / YELLOW
AT COIL *
Parking Lights:
BROWN (+)
DRIVER KICK PANEL OR HEADLIGHT SWITCH
Headlights:
RED / YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm  Disarm:
DARK GREEN/ PURPLE (-)
DRIVER KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Ignition Control Module (ICM) Located On Driver Rear Of Fender Panel. Powertrain Control Module (PCM) Located On Driver Firewall. SPOUT Connector Is Located Near ICM. SPOUT Connector Is A 2 Pin Plug With 2 PINK Wires, Either PINK Wire Is OK. ** See Note #127 - Ford Ignition Switch Connection Diagram.
Ford
Pickup F Series
1994-1995
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
YELLOW (5)
Starter  Kill:
RED / LIGHT BLUE
Ignition  +12 Volts:
RED / LIGHT GREEN
Dome  Lights/Superv:
BLACK/ LIGHT BLUE
DRIVER KICK PANEL OR AT PIN SWITCH
OEM Horn:
DARK BLUE (-)
STEERING COLUMN HARN OR BEAM SEL SW.
Power  Lock:
PINK / YELLOW
FIND WIRES IN PASSENGER KICK PANEL
Power  Unlock:
PINK/LIGHT GREEN
BUT TEST FROM DRIVER'S SWITCH !!! ***
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ LIGHT BLUE
Notes:
*** Without OEM Keyless Entry See Note #203 - Reverse Polarity Door Lock Diagram, With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram.
Posted By: auex
Date Posted: March 25, 2004 at 11:31 PM
If it is reverse polarity and you wired the switch side and motor side of one or both of the lock and unlock wires backwards then you would have blown the fuse. Check that first.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: March 25, 2004 at 11:56 PM
my locks still work from the door switches......just not threw the alarm.....
