94 Mustang door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29042
Printed Date: April 07, 2026 at 1:52 PM
Topic: 94 Mustang door locks
Posted By: deanoho
Subject: 94 Mustang door locks
Date Posted: March 25, 2004 at 9:45 PM
I get this reading, "both motor legs of the door locks are normally open. They neither rest at ground or 12v(+). The switch, when moved in either direction, applies both power and ground directly to them without the use of any relays." And wire it to a BW-3000 as per the diagram But when I hook it ,it blows a 20A fuse!
When not wired to the car the relays function properly.
How many amps does factory actuators draw?
Posted By: draasch
Date Posted: March 26, 2004 at 12:10 AM
Power Lock PINK / YELLOW DR. KICK PANEL IN HARN. BELOW #201
Power Unlock PINK/L GREEN CARPET OR BEHIND GLOVE BOX * #203
* Without OEM Keyless Entry See Note #203, With OEM Keyless See Note #201. #203- See Reversal Rest At Door Lock Diagram. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: raydawg357
Date Posted: March 26, 2004 at 10:33 AM
You have whats called a five wire set up.  Refer to the relay diagram for the proper configuration.
Do it right the first time
Posted By: Steve #1
Date Posted: March 27, 2004 at 3:30 AM
deanoho, what you have read (and quoted above) is true in part. The key is that this is only for vehicles WITHOUT factory remote keyless entry. IF the vehicle has factory remote keyless entry, the locks are negative trigger.
Posted By: deanoho
Date Posted: March 27, 2004 at 8:22 AM
Thanks for all your help guys,
After testing again I found that i do have a 5 wire setup ,I guess i did'nt have a good ground on my meter while testing the first time.
