2002 Accord transponder bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29107
Printed Date: April 06, 2026 at 2:14 PM
Topic: 2002 Accord transponder bypass
Posted By: nannaki
Subject: 2002 Accord transponder bypass
Date Posted: March 27, 2004 at 10:41 AM
First I want to say Hello everyone.
I'm trying to install the 555h transponder bypass to the 02 accord. I had the remote start setup already. I like to ask whether anyone here has any knowledge of where is the ecm wire(tach wire?). I am at the last three wire BLACK / YELLOW;BLACK/ white;yellow.
I've been reading through the forum for info. I did not see any wiring diagram for mainly the 555h.
this is my setup so far
blue/white ->blue/white on top of key cyclinder
black-> ground
blue->to the ground output of the alarm
red-> 12 volt constant
BLACK / YELLOW->? to where is it located?
BLACK/ white->? to where is it located?
yellow->? to where is it located?
Posted By: Velocity Motors
Date Posted: March 27, 2004 at 10:58 AM
If your hooking up the wires for the Immobilizer bypass the ECM wire is with all the other wires for connection ( Synchro, ground, data ). When they refer to " to ECM " that means that the wire that you have to cut ( the DATA wire ) there is 2 halves to it, the ECM side and the module side. Does this make sense ?
Here are the wires your looking for in the Honda:
SYNCH : BLUE, ORANGE / BLUE or a BLUE/WHITE
DATA: RED or a BLUE/GREEN
KEY SENSE : BLUE/WHITE
Posted By: nannaki
Date Posted: March 28, 2004 at 4:16 PM
Thanks Jeff,
I did exactly like you said however when I try to start the remote start wont start. When I remote start it went into accessory and then it shut itself off. Then they key light start flashing for about 5 times and then off. Is it because of the key or wire? or is it the remote start itself? My remote start alarm is FM-2009. Any help is appreciated.
Thanks,
Nick
Date Posted: March 28, 2004 at 4:37 PM
Did the unit confirm that it learned the programming of the key ? Also, make sure that you are using the BLACK key for programming ( this is the master key ) and not the grey key and not the small black key.
