1984 mercedes 300 sd door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29125
Printed Date: April 06, 2026 at 4:52 AM
Topic: 1984 mercedes 300 sd door locks
Posted By: jaggajatt
Subject: 1984 mercedes 300 sd door locks
Date Posted: March 27, 2004 at 7:09 PM
i had a viper 690xv installed in the 300sd, however the installer was not able to get the vacuum door locks to lock and unlock with the remote.  He was able to get it to do one or the other but not both.  does anybody have any ideas to what the problem could be?
Thanks in advance
Jagman
Posted By: atcodoctor
Date Posted: March 27, 2004 at 8:29 PM
Try this link to the door lock area. It shows how to connect vacuum door locks. And I believe if you look around the data base part of this website you will find some more information on Mercedes vacuum door locks.
Also do a search for past posted replies, that has helped me many times.
Good Luck
https://www.the12volt.com/doorlocks/doorlocks.asp
TheDoctor
Posted By: draasch
Date Posted: March 27, 2004 at 8:34 PM
take a look at this digram....the pump (i think) will be under the back seat on the pass. side....
https://wiringinstructions.com/210.htm
if you the relay pack, it makes it so easy to hook you....if you need one, let me know...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
