Turning reverse lights on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29179
Printed Date: April 05, 2026 at 2:40 PM
Topic: Turning reverse lights on
Posted By: Jar2187
Subject: Turning reverse lights on
Date Posted: March 28, 2004 at 12:09 PM
I have a 92 explorer  with an aftermarket prusuit alarm. The new chevys esp. the suvs,when the doors are unlocked with the remote it turns on the reverse lights and the headlights. I want to set my keyless entry up like this. How would I do this?
Posted By: bmf1000d
Date Posted: March 28, 2004 at 3:19 PM
You need to wire relays to mnake both the headlights and the reverse work. YOu have to isolate the reverse and headlights, if you want them when you unlock you have to to hook them to a domelight entry.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Posted By: Velocity Motors
Date Posted: March 28, 2004 at 3:52 PM
BLACK/ PINK (+) at the gear selector switch on the transmission.
Posted By: Jar2187
Date Posted: March 29, 2004 at 4:54 PM
Ok, thats a start. How do I find a remote trigger output on the alarm box. The alarm was put in 93, so its old. The are two wires that are cut on the harness that plugs into the box, dont know what they are for.
Posted By: draasch
Date Posted: March 29, 2004 at 5:17 PM
what model of alarm do you have?
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: Jar2187
Date Posted: March 30, 2004 at 2:28 PM
I dont know what the model number is but I have the Seriel Number. It is 924430500551 -01. I hope this helps. Also if someone knew where I could a wiring diagram.
