Prelude 89 Alarm Installation Remote Strt
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29230
Printed Date: April 06, 2026 at 4:06 PM
Topic: Prelude 89 Alarm Installation Remote Strt
Posted By: Tengoku
Subject: Prelude 89 Alarm Installation Remote Strt
Date Posted: March 29, 2004 at 3:20 AM
Ive searched and looked at all the posts pertaining to this topic and read them all, hoping it will help me complete the wiring that i need for my alarm.. I also surfed https://www.the12volt.com
Ive scanned these diagrams! can you guys help me link what I need to connect?! you guys are soo cool!  :roll:
I need to know what color I should connect in this blue diagram..
heres what I got so far (sorry for the big pics)
posted_image
heres the whole wiring diagram for the car
posted_imageposted_image
and heres what I need to connect
posted_image
thanx in advance
Posted By: draasch
Date Posted: March 29, 2004 at 5:57 AM
Make:   Honda
Model: Prelude
Year:    1988-91
Alarm
Constant 12 volts WHITE/ BLACK AND WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE (-) WHITE CONNECTOR RIGHT OF COLUMN
Trunk Pin Switch GREEN/ BLACK (-) TRUNK LIGHT OR DRIVER KICK PANEL
Parking Lamp RED / BLACK (+) AT LIGHT SWITCH OR FUSE BOX
Power Lock GREEN / WHITE DRIVER KICK PANEL #201
Power Unlock GREEN/ RED DRIVER KICK PANEL #201
#201- See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal BLUE AT COIL
Ignition #2 YELLOW IGNITION SWITCH HARNESS
Ignition #3 BLUE/WHITE IGNITION SWITCH HARNESS
Accessory WHITE/ RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light GREEN/ BLACK (+) AT SWITCH BELOW CONSOLE
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: Tengoku
Date Posted: March 30, 2004 at 1:43 AM
can someone help me locat the trunk pin.. i looked in the kick panel, and I see a hole bunch of relays with wires connected to them all with the same color as the trunk pin (green black).. which one is it????
Posted By: lewdlude
Date Posted: April 28, 2004 at 8:10 AM
Take a volt meter and test the wires with the trunk open. Then close the trunk and check all the ones that had power with it open. The one that changes with the trunk is the correct wire.
89 Prelude Si2.0
-JVC deck, Alpine 6.5's, Lanzar amp for Lanzar 6x9's, Xplod amp for 2 Xplod 10s
"Drive fast and don't take any of this stuff seriously." - Some kid from Space Camp
