1998 vw cabrio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29380
Printed Date: May 13, 2026 at 6:29 AM
Topic: 1998 vw cabrio
Posted By: p01110101
Subject: 1998 vw cabrio
Date Posted: March 30, 2004 at 11:08 PM
1998 volkswagon cabrio alarm info?
Posted By: draasch
Date Posted: March 30, 2004 at 11:35 PM
here is what i have:
Make:   Volkswagen
Model: Cabriolet
Year:    1998
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK IGNITION SWITCH HARNESS
Starter RED / BLACK IGNITION SWITCH HARNESS
Dome Light BROWN / WHITE (-) DRIVER KICK PANEL
Trunk Pin Switch BROWN / RED (-) AT TRUNK SWITCH OR TRUNK LIGHT
Parking Lamp GREY/RED (DR)+GREY/BLK (PS) AT FUSE PNL BEHIND DRIVER DASH *
Power Lock GREY/GREEN SWITCH IN CENTER CONSOLE OR AT #210
Power Unlock VACUUM DOOR LOCKS PUMP IN RIGHT REAR OF TRUNK
#210 See Mercedes Vacuum Door Lock Circuit * Split Parking Light Circuit - Must Relay Isolate Or Diode Isolate (6 Amp)
Remote Start
Tach Signal
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory N/A
Neutral Safety
Brake Light RED / BLACK (+) SWITCH ABOVE BRAKE PEDAL
Reverse Light BLACK/ BLUE (+) FUSE PANEL (UNDER DRIVER DASH)
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
