Disarm 1997 Ford Explorer Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29388
Printed Date: May 13, 2026 at 8:20 AM
Topic: Disarm 1997 Ford Explorer Alarm
Posted By: tanz
Subject: Disarm 1997 Ford Explorer Alarm
Date Posted: March 31, 2004 at 5:46 AM
 I need to disarm my 1997 ford explorer alarm for good. Does anyone have a clue how to!
stanz
Posted By: draasch
Date Posted: March 31, 2004 at 6:28 AM
OEM Alarm Disarm D GREEN/ PURPLE (-) DRIVER KICK PANEL
ground this wire...
are you installing ana alarm??
if so most alarms will have a disarm wire that you can hook up and whne you disarm the aftermarket alarm, it will take care of the factory one as well..
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: tanz
Date Posted: March 31, 2004 at 4:38 PM
 i just need to  uninstall a factory alarm. i am not replacing it. i have a keyless entry, if i us a disarm wire will it afect that. what kind of wire do i use and what do i do with it??(ground it out?)
stanz
Posted By: draasch
Date Posted: March 31, 2004 at 11:09 PM
i need more info on the K/E. why dont you just use the alarm???? it should give you K/E..
Good Luck
David
Ace Security
813-376-9778
Tampa
