Clifford RSX 3.5 info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29479
Printed Date: May 14, 2026 at 7:36 AM
Topic: Clifford RSX 3.5 info
Posted By: Fifty_Cent
Subject: Clifford RSX 3.5 info
Date Posted: April 01, 2004 at 2:31 PM
I need to install a car alarm on my car. I saw the CLIFFORD RSX 3.5 and it seems pretty cool.Problem is, the Clifford dealer looks a bit dodgy to me, and I want to have my own electrician to install the alarm.Is the install straight forward, or does it involve scessive modifications?I dont need/want to install the remote start, if this helps.I dont want to disable the car's immobiliser. P.S. I got a retail price of 500$ for the alarm unit.
Posted By: Javelin3o4
Date Posted: April 01, 2004 at 5:38 PM
if you dont want the remote start why didnt you buy the the matrix 2.5? its the same as the 3.5 but with no remote start
Posted By: sroth140
Date Posted: April 01, 2004 at 5:54 PM
and what kind of car do you have that needs the factory immobilizer "disabled"? ive never "disabled" one. there are integration parts commonly called bypasses.... but they dont "disable" anything. think about it... if you have a 1999 cavalier with passlock.. you need a 555L to learn the cars passlock code and duplicate it for RS. now, when you put the key in a turn it, the car starts, if you shove a fork in the key hole and just happen to manage turning on the ignition, the car still wont cranks because the code isnt being sent. they only time someone might "disable" factory anti theft is on VATS. and thats if the installer does a shady job and just crimps a resistor across the VATS wires. anything else is left intact. think about it, if you jump in a car and hit the brake, the RS dies. the wheel lock is still on, they cant turn on the ignition, or shift. as far as the 3.5 goes, the starter kill is built into the RS harness and you have to have the ignition wires hooked up to program the brain... basically you just did the remote start. all you have left is a door trigger, siren, and shock harness (also lock wires if you have them). ------------- MECP certified installer
Date Posted: April 02, 2004 at 7:13 AM
See what I mean when I say that the dealer is dodgy??? I stated that I dont want the autostart, so he offered to install the 3.5 without the autostart install, but he should have stated me the 2.5. I didnt even know that there is a 2.5. I am not familiar with electronics. I will give him a call and state if there is a 2.5, and then see what he says. Does the 2.5 have all the "responder" functions? Does it involve excessive installation, or is it easier than the 3.5?
Posted By: kgerry
Date Posted: April 02, 2004 at 8:44 AM
it is the exact same unit as the 3.5 except that it is Security only...with no RS which means you can install it in manual transmission vehicles as well... only thing i would mention and i dont know if the warranty is different there, but here there is no warranty on any Clifford products UNLESS it's installed by an authorized Directed dealer. you may want to check into this...... ------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: April 02, 2004 at 2:38 PM
HM, ILL HAVE TO ASK ON THAT ONE. Anyways,the dealer does not have the 2.5. only 3.5. He says he will install it for me if I want, with a charge of course. I wonder, how difficult it is to install the 3.5 without the remote starter?? does it involve taKING LOTS OF TRIM OUT OF THE CAR, and putting it back? I dont want to spoil my porche's interior, if you know what i mean... He said something about passing a wire all the way to the storage compartment(boot). He will remove side trims, etc, and then put them back!!! That is .... scary!
Posted By: bmf1000d
Date Posted: April 02, 2004 at 2:48 PM
what kind of porche do you have is it? ------------- "Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Posted By: sbhh101
Date Posted: April 02, 2004 at 3:37 PM
hey a good alarm with no remote start Viper 591XV 2-Way Remote Start System with Responder Technology 4 channel remote start* system with 2 auxiliary outputs for additional remote control conveniences.*
Posted By: sbhh101
Date Posted: April 02, 2004 at 3:39 PM
hey sorry wrong alarm this is the one Viper 690 XV 2-Way Security System with Responder Technology 3 channel security system with 2 auxiliary outputs for additional remote control conveniences.*
Posted By: mobile1
Date Posted: April 03, 2004 at 1:03 AM
you can go to some electronics places and get it installed for free, as long as you buy it there. matrix 2.5 retails for i think $399
Date Posted: April 04, 2004 at 11:47 AM
Guys, i live in Nicosia, Cyprus, not the US. Here we dont have much options. I should be happy that I found the RSX 3.5 at the first place!!! No viper here, etc. All that I am trying to find out is if that alarm is difficult to install. I got the diagram, but since I odnt know alot about electronics, I cannot really read it. I seems like alot of wires though... Is it that difficult?
Posted By: profuse007
Date Posted: April 04, 2004 at 1:36 PM
the first thing i recommend ppl to get to know the:
-relay, how it works.
-DMM, digital meter, how to test for wires w/o relying on a reference or diagram.
-take ur time to lay out wires so wires wont be running all under the dash.
-the first car that i did, i didnt have a diagram or a reference to rely on, all i have was my brain and the DMM and it came out very smooth.
-other than that its just a matter of reading your manual and plug and chug.
------------- Houston,TX
Date Posted: April 04, 2004 at 3:00 PM
So a reputable electrician who knows his job well, by having the car's diagram and the alarm's, can do the job no problem, right? Oe should I gamble and have the Clifford dealer install it?
Posted By: rudbwoy69camaro
Date Posted: April 04, 2004 at 7:36 PM
Issues.... "Or should I gamble and have the Clifford dealer install it?" They sell the product, it'll be definitely be under warranty. If anything goes wrong...sue them. What kind of precious "poruse" do you have anyway? -------------
Date Posted: April 05, 2004 at 1:59 PM
Sue them...yeah right, after they f**k up my car. things here ins Cyprus are not like the US. To sue someone needs alot of efford and persistence, and a trial may last upto 5 years. I have a 1998 Carrera coupe.
Posted By: kgerry
Date Posted: April 06, 2004 at 9:25 AM
bottom line my man.... spring the few bucks and get it professionally installed
Owner/Installer
Classic Car Audio
since 1979
Date Posted: April 06, 2004 at 9:49 AM
When you say "professionally installed" do you mean the Clifford dealer, or a good electrician/?? I certainly wont be putting the thing myself!!
Posted By: kgerry
Date Posted: April 07, 2004 at 9:15 AM
Mobile electronics and house wiring are two totally different industries for a reason..... i know i wouldn't let an electrician loose in my vehicle.... take it to a car audio/security professional !!! ------------- Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: sroth140
Date Posted: April 08, 2004 at 1:44 AM
also mechanic does not equal mobile electornics installer. they throw fits when cars with alarm/remote starts come in for warranty work. they come up with things like the blinking light on the aiwa radio caused the muffler to fail. sure it did..... im still amazed by the mechanic who called my install bay telling me its our fault that a customers remote start doesnt work after he relpaced a coil pack. GEE DID YA CUT THE TACH WIRE?! uhh i did cut a wire from a harness.... wow, a car with a remote starter and a wire running to a coil pack... HMMM. hook it back up and reprogram the tach signal. DO WHAT, YOU GUYS ARE PAYING FOR IT, paying for what, 30 seconds of labor... you installed the damn thing and you cant solder a wire? lesson to learn: pay someone who does it every day for a living. that is their job. not something they think they can handle. cars now have to much sensitive electronics and immobilizers to just be hacking away in. ------------- MECP certified installer
