Omega Max and 86 4runner rear window
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29626
Printed Date: May 15, 2026 at 4:47 PM
Topic: Omega Max and 86 4runner rear window
Posted By: toyota_4runner
Subject: Omega Max and 86 4runner rear window
Date Posted: April 03, 2004 at 8:55 PM
( after reading comments from you guys) I have almost decided to buy Omega Max with Echo for my 1986 4runner. I was wondering if I would be able to roll the rear window (tailgate) using this system . I searched for answers in this forum and found this useful:
https://www.the12volt.com/installbay/forum_posts.asp?tid=18629&KW=4runner+rear+window
It says the alarm system shd have spare number of channels and someone said I can use the truck release, these things dont make much sense to me, probably ll make more sense when I get the module and read the instructions. But for now, if someone can tell if the omega max can do the job or I ll have to buy soemthing else, that will be great!
Thanks in advance!
Posted By: draasch
Date Posted: April 04, 2004 at 9:22 AM
depending on teh module you buy, you should be able to use the 2nd channel for that
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
