Installing alarm in 2000 s10
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29648
Printed Date: May 15, 2026 at 10:20 PM
Topic: Installing alarm in 2000 s10
Posted By: devilman
Subject: Installing alarm in 2000 s10
Date Posted: April 04, 2004 at 6:09 AM
Hi all. Great forum. Im going to install a Crime Guard 533i2 in a chevy s10. I found the diagrams for the s10 on the home page, but when i did a search for the 533i2 diagram, I found where The12Volt had posted a link for www.caralarm.com When i clicked on the link, the page could not open. Can anyone point me in another direction for the alarm installation diagram? Thanks!
Posted By: draasch
Date Posted: April 04, 2004 at 9:07 AM
im not sure if you have a pickup... but here the info for the p/u:
Make:   Chevrolet
Model: S-10 Pickup
Year:    2000
Alarm
Constant 12 volts RED (2) IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT BODY RELAY BLOCK *
Trunk Pin Switch
Parking Lamp L BLUE (+) AT HEADLIGHT SWITCH
Power Lock L BLUE AT RELAYS IN #202
Power Unlock WHITE DRIVER KICK
* Body Relay Block Is Located Above Driver Kick Panel Area Near Fuse Block. Alternative Door Trigger:TAN (-) Covers Driver Door Only. ORANGE (-) Covers Passenger Front Door. D BLUE/WHITE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. Wires Located At BCM Behind Passenger Dash On Heater Core. #202- See Positive Pulse Door Lock Diagram.
Remote Start
Tach Signal WHITE AT IGNITION CONTROL MODULE * #238
Ignition #2 WHITE IGNITION SWITCH HARNESS
Ignition #3 ORANGE IGNITION SWITCH HARNESS
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) AT UNDER HOOD FUSE BOX
Rear Window Defrost N/A TIMER BUILT INTO SWITCH
* Ignition Control Module Is Located On The Passenger Side Of The Engine Compartment. Wire Can Also Be Found As WHITE At Inst Cluster Or PCM On Passenger Side Of Engine Copmartment. #238 - See G.M. PASSLOCK II Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: devilman
Date Posted: April 04, 2004 at 1:58 PM
Thanks for the pickup info, Now if i could find the alarm info. posted_image
Posted By: devilman
Date Posted: April 04, 2004 at 6:52 PM
Well guys, I went back to caralarm.com today and the page opened, but I still can't seem to get a diagram. Thanks for your help.
Posted By: draasch
Date Posted: April 04, 2004 at 8:26 PM
https://www.caralarm.com/maunals/cg533i3.pdf
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: devilman
Date Posted: April 08, 2004 at 5:14 AM
Thanks, I looked through that, but didnt see a wiring diagram.
Posted By: draasch
Date Posted: April 08, 2004 at 9:14 AM
i have a manual on its way...when i get it i'll let you know.
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: devilman
Date Posted: April 08, 2004 at 1:57 PM
Thanks, man. I really appreciate it.  posted_image
Posted By: devilman
Date Posted: April 14, 2004 at 2:31 PM
Any luck?
