Online BitWriter Manual
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29715
Printed Date: May 16, 2026 at 12:16 PM
Topic: Online BitWriter Manual
Posted By: Twentyvee
Subject: Online BitWriter Manual
Date Posted: April 05, 2004 at 11:09 AM
Can someone direct me towards an online users manual for the Directed Bitwriter. Thanks
Posted By: kgerry
Date Posted: April 05, 2004 at 4:45 PM
sure    go to DEI's site and log-in......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: auex
Date Posted: April 05, 2004 at 6:35 PM
There isn't much to it. Plug it in to the black port on the alarm and push read. Then go through and select what options you want to change. Then select what transmitter you want to use for the options you selected, select transmitter 0 if you want all transmitters, and then push write. That is really it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
