2000 excursion f/alarm help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29792
Printed Date: March 17, 2026 at 5:03 PM
Topic: 2000 excursion f/alarm help
Posted By: mractransit
Subject: 2000 excursion f/alarm help
Date Posted: April 06, 2004 at 4:14 AM
IM TRING TO INS TALL A ALARM IN A 2000 EXCURSION, I GOT IT HOCKED UP EXEPED FOR THE DOME LIGHTS AND LOCKS, I CANT FIND THE MODUAL THAT CONTROLS IT, IM SUPOSED TO TAP IN TO PIN 22 AND 26 OF THE CONTROLL MODUAL, ANY SUGESTIONS WILL BI GRATELY APPRUSIATED :D
Posted By: draasch
Date Posted: April 06, 2004 at 7:02 AM
Make:   Ford
Model: Excursion
Year:    2000
Alarm
Constant 12 volts L GRN/PPL(2) & YEL(2) IGNITION SWITCH HARNESS
Ignition 12 volts RED / BLACK IGNITION SWITCH HARNESS
Starter RED / BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ BLUE (+) 40 PIN CONNECTOR ON FIREWALL * **
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW EITHER KICK ** #201
Power Unlock PINK/GREEN PANEL
* 40 Pin Connector Is Mounted On Firewall Behind The Driver Dash Top Of Two Other 40 Pin Connectors ** See Tech Notes For Alternate Locations and/or Wire Colors #201 - See Negative Pulse Door Lock Diagram.
Installer Note: BLACK/ Pink 22 Gage Wire In Big Wire Harness Far Left Side Alternate Door Trigger Color is ORANGE / GREEN (-) At Headlight Switch Or BLACK/ BLUE Behind Center Of Instrement Panel 16 Pin conn. Alternate Door Lock Switch Wire Location Is Behind Glovebox, Above Heater Case. Test for Switch Side From Driver's Switch.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
