SC2 Keyless Entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29820
Printed Date: March 18, 2026 at 12:01 AM
Topic: SC2 Keyless Entry
Posted By: JTMAG1
Subject: SC2 Keyless Entry
Date Posted: April 06, 2004 at 2:04 PM
I just installed a freedom 500 KEyless entry system into my 95 Saturn SC2. Everything works but the Keyless Entry. I even tried patching the wiring just behind the actuators to make sure that I had the correct wires, and there was still no respone. According to the directions that I have, I did everything right. Am I supposed to do something with the Orange wire thats between the white and the Blue?¿?¿?
Posted By: kgerry
Date Posted: April 07, 2004 at 1:46 PM
you installed a keyless entry system and everything works fine except the keyless entry...   I'm confused... what is it that works fine???
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Javelin3o4
Date Posted: April 07, 2004 at 3:57 PM
if you went directly to the actuators you would have to use a relay like a 451M.
POWER LOCK           lt. blue            |+  |either kick harness to rear |
POWER UNLOCK     white              |+  |either kick harness to rear |
Posted By: JTMAG1
Date Posted: April 07, 2004 at 11:59 PM
The Alarm part works fine, it chirps and the lights flash.
Posted By: JTMAG1
Date Posted: April 08, 2004 at 12:14 AM
Just to Clarify, what is meant by driver kick harness or Passenger Side Rear Body Harness. Where can I get the relay that I need?
Posted By: sroth140
Date Posted: April 08, 2004 at 12:58 AM
the drivers kick panel is just that... the panel the driver kicks...  big trunk of wires behind the carpet on the left.
a 2000 saturn S-series should have (+) trigger locks with lock being lt. blue and unlock being white.  grab said wire you may suspect to be right, and test for voltage at zero, then going to 12 when you press the desired lock/unlock function.
MECP certified installer
Posted By: JTMAG1
Date Posted: April 11, 2004 at 12:18 AM
Thanks for the help, I picked up that relay and it made everything go smoothly
