problem starting with APS996a
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30067
Printed Date: March 21, 2026 at 11:04 PM
Topic: problem starting with APS996a
Posted By: gearheads78
Subject: problem starting with APS996a
Date Posted: April 09, 2004 at 6:12 PM
OK yesterday I finally finished installing in a 99 Tahoe. Everything works perfect except the remote start. When I hit the button twice to start the lights flash but nothing else happens. I know it is possible to be a instalation error but I really don't think so. I was triple checking everything along the way of the install. Has anyone else experienced a similar problem on this unit? What are the chances of this just being a bad alarm brain?
Posted By: tjdurham
Date Posted: April 09, 2004 at 11:18 PM
did you bypass the passlock2 system that is a pretty reliable system so check your work and did you program tach??
tj
Date Posted: April 10, 2004 at 12:01 AM
Yes that is all taken car of. The problem is the starter will not engage. You can feel and here a relay inside the box that switches the lights on but that is all that happens. Even if it was a tach problem or Passlock the starter does ot turn to find out.
Posted By: x6369x
Date Posted: April 10, 2004 at 1:25 AM
Do the Audiovox unit have some sort of shut down diagnostics. DEI units have a shut down diagnostics that uses LED flashes to report why the alarm won't remote start.
Friends Don't Let Friends Bump Stock.
Date Posted: April 25, 2004 at 10:08 PM
After beating my head against a wall for a couple of hours I figured it out. Now its works perfect. I went back and read the instuctions. I never put the alarm in a learn mode for the tach signal. As soon as I did that all is well.
This sight has been a big help. I was very skeptacle about taking our truck to someone else that may or may not have know what he was doing. Also now I am the only one that knows where what is. I like it that way.
