2002 honda civic relay siren help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30165
Printed Date: March 20, 2026 at 12:43 AM
Topic: 2002 honda civic relay siren help
Posted By: sdazn02civic
Subject: 2002 honda civic relay siren help
Date Posted: April 11, 2004 at 1:16 PM
I have a Karr alarm system in my car right now and the alarm use the stock horn as a siren for the alarm. I want to add an aftermarket siren ( 6 tones). I have study and research and found alot of information regarding this, but the setup for the relay are different. And I have a negative output from the alarm.
Here what I found:
86-negative out put from alarm
85-ground
87-constant 12v fused
30-out to horn+ aftermarket siren
Is this diagram correct? Please help any information will be very helpful. Thanks!!!
Posted By: desh187
Date Posted: April 11, 2004 at 2:41 PM
this relay configuration is to change your negative output to positive which is correct,now the only thing to remember is that a horn output as it is on your alarm is set as pulsed and a siren output is steady,some alarms have programmable features where this is possible to switch.
if your alarm (which iam not familiar with)does not have this feature,use a relay and before mounting the siren,just have it outside and trigger the alarm.if it sounds okay(usually it would be a pulsing noise-which would sound funny)then mount the siren.
Date Posted: April 11, 2004 at 4:20 PM
Thanks for the info, that really help.
Does anyone know how to make my alarm use the stock horn at a pulsed, but still have the aftermarket w/ 6 tone going as a steady output?
